Sort Order - Numbers in File and Folder Names
How to Change the Sort Order for Numbers in File and Folder Names in Vista
This will show you how to change the default sort order in Windows Explorer for files and folders that contain numbers in their name so that they will be sorted by the number instead of the number's numeric value.
For more information, see: Microsoft Help and Support: KB319827
By default, the sort order in Vista considers strings in file and folder names as numeric content, not text. Numerals in folder and file names are sorted according to their numeric value. In the example below, 401 is a numerically higher value than 6. Therefore, the Ie401sp2.txt file is listed after the Ie6.txt file when you the files are sorted by name in ascending order. In the example below, note how the following files, whose names contain numerals, are sorted.
EXAMPLE: Default Sort Order for Numbers in File and Folder Names
NOTE:
You will just need to see which sort oder you like better to see if you wish to modify it or not.
EXAMPLE: Modified Sort Order for Numbers in File and Folder Names
NOTE:
METHOD ONE
To Change Sort Order with a Download
1. To Modifiy Sort Order for All Users
A) Click on the download button to download the file below.​
Modify_All_Users_Sort_Order.reg
download
B) Go to step 5.​
2. To Restore Default Sort Order for All Users
Default_All_Users_Sort_Order.reg
download
B) Go to step 5.​
3. To Modify Sort Order for Current User Only
Modify_Current_User_Sort_Order.reg
download
B) Go to step 5.​
4. To Restore Default Sort Order for Current User Only
Default_Current_User_Sort_Order.reg
download
5. Click on Save, and save the .reg file to the Desktop.​
6. Right click on the downloaded .reg file and click on Merge.​
7. Click on Run, Continue (UAC), Yes, and then OK when prompted.​
8. Log off and log on, or restart the computer to apply the changes.​
9. When done, you can delete the downloaded .reg file if you like.​
METHOD TWO
To Manually Change Sort Order
1. Open the Start Menu.​
OPTION ONE:
4. To Modify the Sort Order for All Users
A) In regedit, go to: (See screenshot below)​
NOTE: If you do not have Explorer, then right click on Polices and click on New and Key, then type Explorer and press Enter.
Code:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
B) In the right pane, right click on a empty area and click New and DWORD (32-bit) Value.​
C) Type NoStrCmpLogical and press Enter. (See screenshot below)​
D) Right click on NoStrCmpLogical and click on Modify.​
E) Type 1 and click on OK. (See screenshot below)​
F) The registry will now look like this. (See screenshot below)​
5. To Restore the Default Sort Order for All Users
A) In the right pane, right click on NoStrCmpLogical and click on Delete. (See screenshot above.​
6. Log off and log on, or restart the computer to apply the changes. Your Done.​
OPTION TWO:
7. To Modify the Sort Order for Current User Only
Code:
D) Right click on NoStrCmpLogical and click Modify.​
8. To Restore the Default Sort Order for Current User Only
A) In the right pane, right click on NoStrCmpLogical and click on Delete. (See screenshot above)​
9. Log off and log on, or restart the computer to apply the changes.​
  • Default_All_Users_Sort_Order.reg
  • Default_Current_User_Sort_Order.reg
  • Modify_All_Users_Sort_Order.reg
  • Modify_Current_User_Sort_Order.reg
