Vista - Audio Device - Enable Hidden Devices
Comment
Old 03-31-2008
Brink
How to Enable Hidden Audio Devices in Vista
Old 07-18-2009
Brink
Re: Audio Device - Enable Hidden Devices
Hopefully someone with the same audio device as you can confirm the same thing as you soon.
Old 08-18-2009
Vortex93
Vista Home Premium 64Bit
Hi Brink, is there a way to enable a way of recording the sound in the computer without using a microphone, in xp i could have done that, but not in vista..
Old 08-18-2009
Brink
Hello Vortex,
You should be able to record sounds played on the computer using Sound Recorder at C:\Windows\System32\SoundRecorder.exe.
Old 08-18-2009
Vortex93
Thnx for replying so fast , but what i ment was like when i play a music, it records what happends on the desktop not via the mic, if i put my mic on the speakers it won't record the sound perfectly, if you know what i mean ...
Old 08-18-2009
Brink
Sorry Vortex,
You will need to do this first.
"What U Hear" Recording - Enable - Windows 7 Forums
Old 08-18-2009
Vortex93
Thnx a lot Brink Ur Awesome !
Old 08-18-2009
Brink
You're welcome.
Comment
Tutorial Tools
Tutorial Category
Disable and Enable Devices PowerShell
Device Manager - Hidden Devices Tutorials
multiple bluetooth devices in device manager, but only one device installed????? Drivers
Audio device stopped working - Reproduction devices list is empty Vista hardware & devices
Permanently Set Dev. Mgr. to Show Hidden Devices Vista General
