Send To - Add or Remove from Context Menu
How to Add or Remove Send To from Context Menu in Vista
This will show you how to add or remove the Send To context menu, right click on a file or folder, item for all users on the computer. By default, Send To is added to the context menu.
EXAMPLE: Send To added or removed from the Context menu
OPTION ONE
Using a REG File Download
1. To Add Send To
Add_Send_To_Menu.reg
download
B) Go to step 3.​
2. To Remove Send To
Remove_Send_To_Menu.reg
download
  • Add_Send_To_Menu.reg
  • Remove_Send_To_Menu.reg
You're most welcome hgjazz. :)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
