How to Add or Remove Send To from Context Menu in Vista
Information
This will show you how to add or remove the Send To context menu, right click on a file or folder, item for all users on the computer. By default, Send To is added to the context menu.
EXAMPLE: Send To added or removed from the Context menu
OPTION ONE
Using a REG File Download
1. To Add Send To
A) Click on the Download button below to download the file below.
Add_Send_To_Menu.reg
B) Go to step 3.
2. To Remove Send To
Remove_Send_To_Menu.reg
