Task Manager - Always On Top
How to Turn Task Manager "Always On Top" On or Off
This will show you how to turn the Task Manager option of Always On Top of other windows on or off in Vista and Windows 7.
Having Always On Top turned on will have Task Manager to always be on top of any open window. This can make the Task Manager a lot easier to find and use when needed.
1. Open the Task Manager.​
NOTE: To open the Task Manager press CTRL+SHIFT+ESC, or right click on the taskbar and click on Task Manager.​
2. Click on Options on the menu bar. (see screenshot below step 4)​
3. To Turn On Always On Top
A) Click on Always On Top to check it. (see screenshot below step 4)​
4. To Turn Off Always On Top
A) Click on Always On Top to uncheck it. (see screenshot below)​
