User Logon Display Picture - Set Default for All Users
How to Set a Default User Logon Picture for All Users in Vista, Windows 7, and Windows 8
This tutorial will show you how to set a default user logon picture that cannot be changed for all users in Vista, Windows 7, Windows 8, and Windows 8.1.
This can be handy if you would like all accounts to display say a company logo as their default user account picture.
The only drawback, is that the user logon display picture in the Start menu in Vista and Windows 7 will be blank with this option enabled. (see screenshot below)
This will not work if you have it set to where a user must enter both a user name and password at log on instead of just selecting a user icon as in the example screenshot below.
EXAMPLE: Logon Screen with a User Logon Display Picture
STEP ONE
Change Default User and Guest Logon Picture
You can select to use any BMP, DIB, RLE, GIF, JPG, or PNG image file for the display picture. The image can only be up to 128 x 128 pixels in size to prevent it from being automatically cropped to fit the user display box. If it is bigger than this, just resize it. Otherwise, your image may be cut off or not centered properly.
These are the images used for the default user (standard and administrator) and guest logon display picture for the user accounts. ProgramData is a hidden system file.
For: Vista, Windows 7, and Windows 8
Accounts
Default Picture Location
Guest
C:\ProgramData\Microsoft\User Account Pictures\guest.bmp
Standard
C:\ProgramData\Microsoft\User Account Pictures\user.bmp
Administrator
For: Windows 8.1
Accounts
Guest
C:\ProgramData\Microsoft\Default Account Pictures\guest.bmp
Standard
C:\ProgramData\Microsoft\Default Account Pictures\user.bmp
Administrator
1. Name the image that you want to use to user.bmp and/or guest.bmp for the account type you want it as the default for.​
2. Make sure that you have Show hidden files and folders selected in Folder Options.​
3. In explorer, navigate to the location below. (See screenshot below)​
(Vista, Windows 7, and Windows 8)​
OR
A) For the default logon picture you want to change, right click on user.bmp or guest.bmp, and click Rename.​
B) Rename them to user.bmp.bak and/or guest.bmp.bak, press Enter, then click Yes, Continue, and Continue.​
C) Right click on the image from step 1 and click on Copy, click on an empty area in this window, and click Paste.​
NOTE: To undo this, delete the new image from step 4C and remove the .bak off the name of user.bmp.bak and/or guest.bmp.bak to restore the default images given by Vista.​
4. Close this window when done.​
5. Select Do not show hidden files and folders in Folder Options.​
STEP TWO
Set or Unset a Default Logon Picture for All Users
WARNING: You must change the default images in the STEP ONE section above first to what you want to be used by all user accounts, then use either METHOD ONE, METHOD TWO, or METHOD THREE below to apply the image.
Method One
NOTE: This method is only available in the Vista Business, Ultimate, and Enterprise editions or Windows 7 Professional, Ultimate, and Enterprise editions.. See Method Two or Method Three below for all other editions.​
2. In the left pane, click on Computer Configuration, Administrative Templates, Control Panel, and User Accounts (See screenshot below)​
3. In the right pane, right click on Apply the default user logon picture to all users and click on Properties. (See screenshot above)​
4. To Unset Default Logon Pictures for All Users
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5A)​
B) Go to step 6.​
5. To Set Default Logon Pictures for All Users
A) Dot Enabled and click on OK.​
6. Close Local Group Policy Editor window.​
7. Log off and log on to see the change for the user logon display picture.​
Method Two
Using a REG File Download
NOTE: This method will work for all Vista editions.​
1. To Set Default Logon Pictures for All Users
A) Click on the Download button to download the file below.​
Set_Default_Logon_Picture.reg
download
B) Go to step 3.​
2. To Unset Default Logon Pictures for All Users
Unset_Default_Logon_Picture.reg
download
3. Save the .reg file to your Desktop.​
4. Double click/tap on the downloaded .reg file to merge it.​
5. Click/tap on Run, Continue (UAC) or Yes (UAC-Windows 7/8), Yes, and then OK when prompted.​
6. When done, you can delete the .reg file (On Desktop).​
7. Log off and log on, or restart the computer to apply and see changes.​
Method Three
Manually in Registry Editor
1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.​
2. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7/8).​
3. In regedit, go to: (See screenshot below)​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
4. To Set Default Logon Pictures for All Users
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
B) Type UseDefaultTile and press Enter.​
C) Right click on UseDefaultTile and click on Modify. (See screenshot below)​
F) Go to step 6.​
5. To Unset Default Logon Pictures for All Users
A) In the right pane, right click on UseDefaultTile and click on Delete. (See screenshot above)​
6. Close regedit.​
  • Set_Default_Logon_Picture.reg
  • UnSet_Default_Logon_Picture.reg
Re: User Account Default Logon Display Picture
That works great if you are allowing user accounts to be displayed. My question is if you are running on a domain and you don't show the last username that logged on, how do change the blank picture frame to show a company logo?
Hello Aldorian, and welcome to Vista Forums.
This can help how you how to have information about previous user logons display at logon.
How to Display Information About Previous Logons During User Logon in Vista
Unfortunately, there is no way to change the blank picture using the option in this tutorial though. :(
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thank you. I understand that this tutorial doesn't have that option but my question is if it is possible to change the blank picture to be a company logo? Where would these images be stored? For example, when using a Smart Card, that window has a Smart Card icon, where is that image and can it be changed? It has to be somewhere in a .dll or other file somewhere on the system. And there is probably a registry entry somewhere that controls it as well. I was just wondering if anyone new where that was?
From my understanding it was a bug that caused the blank Start Menu user picture when using the option in the tutorial. Normally the image used for this would be either the default user.bmp file, or the individual picture the user assigned that is overridden by the option in the tutorial.
If there is a way around, I have not found it yet other than manually changing the user display picture in each account and telling them not to change it.
I'll keep by eye out for any type of other workaround and post back with it if I can find one.
Greetings,
First I would like to thank you all for posting information regarding this topic. I was delighted to find this out there.
I'm also a little fustrated and wondering if anyone has come accross the problem we are experienceing. We have followed all the steps outlined in Method 1 above. I have read and re-read the documentation and followed all the steps to the best of my ability.
However, we are still not able to set the default picture on our systems. We would like to have the company logo displayed for all users. We are also trying to achieve setting a default user so that only one logon appears when the system is booted up. As it stands today we are not able to set the default picture for a single default user on our Vista system.
We have been successful at setting the default picture for all users and having this show up on the desktop. But this is the option where all the user show up on the desktop and then you select which user to sigon with. We don't want this. We are looking to set a default user and along with that set a the default logo picture for that single user. Following the steps above we are not able to do this.
Has anyone else expereinced this issue where you were not able to set the default picture AFTER following the steps in any of the Methods listed above? I'm scratching my head. This is the last item for our Company Vista build and i'm pulling my hair out trying to fix this. I've spent enought time on this topic. Any other ideas or suggestions out there? Thank you
fuzzymnky
    Dell Optiplex 755
Hello Fuzzymky, and welcome to Vista Forums.
The methods in the tutorial should change the default user picture only on the log on screen. It unfortunately will leave the Start Menu user picture blank though. Is this what you are seeing?
Shawn,
Thanks for responding. I do appreciate it.
Yes, I'm aware of the start menu picture remaining blank. I'm fine with the start picture remaining blank. What we are tyring to change is exactly what is outlined in the tutorial, which would be the "default user picture".
We have followed the tutorial and are still not able to change the default picture. i'm wondering if there is some other setting or default user setting that we need to modify in order to the get the picture to change.
fuzzymky
    Dell Optiplex 755
If you can upload the image that you are wanting to use, I'll be happy to test it on my system to see what it may be as well. :)
I'll remove the image as soon as I have downloaded it so it will not be available for everyone.
Shawn,
Thanks again, I'm not sure where I would upload the picture to. I work for a small franchise owner and any servers open to public would be hanlded by corporate. I could email you the picture if that works.
Thanks again for the assistance
Dave
    Dell Optiplex 755
That will work. I'll send you a PM. :)
Dave,
Using the setting to have to enter a user name and password at log on would be why it is blank then. There is no option that I am aware of to change the display picture for this since it is not actually a user icon.
The only way that I know of to achieve having the company image used instead, is to have it where you select a user icon at log on instead while using the method in this tutorial.
Sorry. :(
Thank you Brink I have been fighting with this stupid flower picture for ages.
The picture on my start up page was one thing and the start menu was still the default. Once you had told me where they were stored I was able to delete the unwanted pictures and replace them with my own. I had to play about a bit with the resize but got it sorted. Thank you. It's funny how little things like that can make a big difference to enjoyment you can have with Vista.I would also like to point out that a lot of people are asking how to do this on the forums I have been on with not much success
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
You're welcome Roger. I know how you feel. Little things like that bug me the most as well.
