| Administrator | Drive - Hide or Unhide How to Hide or Unhide a Drive in Vista Last edited by Brink; 04-22-2009 at 07:09 AM.. |
| Newbie | Re: Drive - Hide or Unhide thanks, i tried removing the readyboost useage from it, rebooted, checked the registry for the dword, it still shows. restarted again. still showing the drive..... |
| Administrator | Re: Drive - Hide or Unhide My guess then is that Vista just will not let you hide a removable drive like a USB flash drive. |
| Newbie | Re: Drive - Hide or Unhide actually this is a partition on my sata ssd that i setup just for readyboost. i figured the 100mb transfer rates were more than enough to do the job well.. mabe its because i have the drive letters hidden.. i'm going to try restarting.. checking the registry, mabe deleting the dword, restarting, putting it back and restarting again. i hope it works.. |
| Administrator | Re: Drive - Hide or Unhide My mistake. I just assumed that since it was ReadyBoost, it was a USB flash drive. ![]() Please post back your results. |
| Newbie | Re: Drive - Hide or Unhide well basically ive got a problem, u said that we should go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer but mine only goes to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies the "Explorer" please help me, and tell me wat to do??? ive attched a screenshot so u can see my problem::: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Administrator | Re: Drive - Hide or Unhide Hello Awargi, The reg file in the ZIP download below will restore this default Explorer key and entries back to your registry. After you have extracted the reg file from the ZIP, just double click on it to merge and approve. Hope this helps, Shawn |
| Newbie | Re: Drive - Hide or Unhide thnx alot that works.. but there is still one problem, that is this only hides the drive from one user, so all the other user accounts on the computer can still see the drive. please help me with this. thnx. |
| Administrator | Re: Drive - Hide or Unhide Awargi, Try doing the manual METHOD TWO at this registry location as well. It should hide it for all users. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer |
| Newbie | Re: Drive - Hide or Unhide yeah same problem as before, there is no "Explorer" option, i cant go any further then "Policies"...... can u please teach me how to add that "explorer" thnx alot |
| Administrator | Re: Drive - Hide or Unhide No problem. In the left pane, you would right click on Policies, and click on New and Key. Type Explorer, and press Enter. |
| Tutorial Tools | |
| Tutorial | Category | |||
| How to Hide Drive in Vista and Still Be Able to Use it. | Vista hardware & devices | |||
| Re: Drive - Hide | Vista security | |||
| Disable/re-enable or hide/unhide Start Menu in Windows Vista via registry, using VB6 | General Discussion | |||
| Computer Name - Hide or Unhide in Network | Tutorials | |||
| Unhide vista c drive | Vista hardware & devices | |||
