Drive - Hide or Unhide
How to Hide or Unhide a Drive in Vista and Windows 7
This will show you how to hide or unhide a drive from being displayed in Computer and Windows Explorer in Vista and Windows 7.
By default, all drives are not hidden.
This will only hide or unhide the drive in Vista and Windows 7, and will not prevent access to the drive from say the command prompt or Run command window.
This will not unhide a drive that was not hidden by this method.
EXAMPLE: The D drive set to Unhide and Hide in Computer
NOTE:
Open the Start menu and click on the Computer button to see this.
METHOD ONE
Using the Local Group Policy Editor
NOTE: For more drive letter options, see Method Three below.
2. In the left pane, click on User Configuration, Administrative Templates, Windows Components, and Windows Explorer. (See screenshot below)​
3. In the right pane, right click on Hide these specified drives in My Computer and click on Properties. (See screenshot above)​
4. To Unhide All Drives
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below step 5C)​
B) Go to step 6.​
5. To Hide a Drive or Combination of Drives
A) Select (dot) Enabled.​
B) Click on the drop down arrow and select the drive or combination of drives option that you want to set as restricted (hidden). (See screenshot below)​
NOTE: Even though the options say Restrict, it is to Hide the drive(s).​
C) Click on OK.​
METHOD TWO
Using a REG File Download
NOTE: Whichever REG file you choose to use, it will overide all of the others. For more drive letter options, see the Method Three below.
1. To Hide A and B drives only
A) download
B) Go to step 8.​
2. To Hide C drive only
A) download
B) Go to step 8.​
3. To Hide D drive only
A) download
B) Go to step 8.​
4. To Hide A, B, and C drives only
A) download
B) Go to step 8.​
5. To Hide A, B, C, and D drives only
A) download
B) Go to step 8.​
6. To Hide All drives
A) download
B) Go to step 8.​
7. To Unhide All drives
A) download
8. Save the .reg file to your Desktop.​
9. Right click on the downloaded .reg file, and click on Merge.​
10. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
11. When done, you can delete the downloaded .reg file if you like.​
12. Log off and log on, or restart the computer to apply changes.​
METHOD THREE
Manually in Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7)..​
3. In regedit, navigate to the location below. (See screenshot below)​
4. To Hide a Drive or Combination of Drives
A) In the right pane of Explorer, right click on a empty area, click on New and DWORD (32-bit) Value, and type NoDrives and press Enter. (See screenshot below)​
B) Right click on NoDrives, and click on Modify.​
C) Type in the drive option hex or decimal number below in bold you want to set as restricted, and click on OK. (See screenshot below)​
To hide multiple drive letters, add the decimal numbers together for each drive letter below that you want to hide, , select (dot) Decimal or Hex for the type of numbers you used, enter that number, and click on OK.
For Example: I'm using 8 (hex number) to Hide D drive only, or for E=16 and F=32, I would use 16+32=48 (Decimal number).​
Drive Letter
Decimal
Hex
A
1
1
B
2
2
C
4
4
D
8
8
E
16
10
F
32
20
G
64
40
H
128
80
I
256
100
J
512
200
K
1024
400
L
2048
800
M
4096
1000
N
8192
2000
O
16384
4000
P
32768
8000
Q
65536
10000
R
131072
20000
S
262144
40000
T
524288
80000
U
1048576
100000
V
2097152
200000
W
4194304
400000
X
8388608
800000
Y
16777216
1000000
Z
33554432
2000000
All Drives
67108863
3ffffff
  • Hide A and B drives only - type 3 (hex)
  • Hide C drive only - type 4 (hex)
  • Hide D drive only - type 8 (hex)
  • Hide A, B, and C drives only - type 7 (hex)
  • Hide A, B, C, and D drives only - type f (hex)
  • Hide all drives - type 3ffffff (hex)
D) The registry will now look like this. (See screenshot below)​
E) Go to step 6.​
5. To Unhide All drives
A) In the right pane of Explorer, right click on NoDrives and click on Delete. (See screenshot above)​
B) Click on Yes to confirm delete.​
6. Close regedit.​
7. Log off and log on, or restart the computer to apply changes.​
  • Hide_A_B_drives.reg
  • Hide_C_drive.reg
  • Hide_D_drive.reg
  • Hide_A_B_C_drives.reg
  • Hide_A_B_C_D_drives.reg
  • Hide_All_drives.reg
  • Unhide_All_drives.reg
I have a partition on my 2nd HDD labeled F: which is my windows vista backup and I want to hide it so you can't even see it but when I attempted these steps I got choices A, B, C, and D for drive letters but that was it. I have a C: and D: (D: is the big partition on the 2nd HDD) and F: (small partition on 2nd HDD) Any clue how I can hide this backup drive?
Hi Poisonpanik,
You will just need to do the manual way instead in METHOD TWO. Dot Decimal and type 32 (for F: drive) in step 5C.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Your welcome Poisonpanik, and welcome to Vista Forums. :party:
Thanks Brink and thanks for the SUPER FAST reply. It worked like a champ! I will be sure and pass the word on about this site. So much good info in one place. It's a gold mine!
Hi Gixykings,
I have a few questions first.
What type of drive is it?
Did you dot Decimal in the Modify window and type 33554432?
Did you restart the computer afterwards to apply the changes?
No problem Gixykings. I'm happy to hear that it is hidden now.
Hey, i have only one option when i got to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer.
Just the default.
I Don't have the "NoDriveTypeAutorun" option.
What should i do?
Sry m8!
Just now tried method 1
that works fine!
But i have Four drives namely C,D,E,F.
Each of 40 gb.
But by method one,i was able to hide only D.
How to hide my other drives?
And Congrats on your 15000th post!:cool:
-Ashok
Hello Ashok, and welcome to Vista Forums.
I suppose that you could hide all of the hard drives to do so. :geek:
Thank you for the 15000th posts congratulations, :party:
Oh, sorry Jeyessh. I misunderstood what you wanted.
You can do this by using the manual option in Method Two. When you get to step 5C, dot Decimal and use 32 for the F drive in the Note under that step.
You're welcome Jeyessh.
Hay there I was wondering if there is anyway for me to hide my B drive and my D drive only.:confused::confused::confused:
    HP m8190a
    Intel Core 2 Quad 2.4Ghz (VIIV)
    Asus IPIBL-LA
    Nvidia Geforce 8600 GT 512MB
    Realtek ALC 888S chipset
    Asus PG221
    1680X1050
    Western Digital 7400RPM 500GB
    8000KB/s
    TV tunes, HD-DVD rom
Hello Techkidguru, and welcome to Vista Forums.
Sorry, not that I am aware of. You could change the permission level of the drives to not Allow other users access though.
1. Right click on the drive and click on Properties.
2. Click on the Security tab.
3. Click on the Edit button.
4. Select a User Name or user Group.
5. Check all of the Deny boxes.
WARNING: Do not include your user name or (Administrators) Group, or you will not have access.
6. Repeat step 4 & 5 for any other user name or group that you do not want to have access.
7. Click OK.
i tried this to remove my I drive (ready boost), restarted, made sure that i selected decimal and entered 256. restarted again. no go. I was wondering if i was doing it right, my dword value shows up as NoDrives REG_DWORD 0x00000100 (256)
Hello t0cableguy, and welcome to Vista Forums.
Since you have it set with ReadyBoost turned on for it, it may not let it be hidden. As a test, turn off ReadyBoost for the the I: drive and see if you can hide it then.
