Taskbar and Start Menu Properties - Enable or Disable
How to Enable or Disable "Taskbar and Start Menu Properties" in Vista and Windows 7
This will allow (enable) or prevent (disabled) the Taskbar and Start Menu Properties window from opening when users on the computer right clicks on a empty space on the Start Menu or Taskbar and clicks on Properties.
EXAMPLE: Taskbar and Start Menu Properties window
EXAMPLE: Error Message
NOTE:
If disabled, this will be the error message that all users will get when they try to right click on the Taskbar or Start Menu and click Properties.
METHOD ONE
Using the Local Group Policy Editor
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions. See Method Two or Method Three below for the Vista Home Basic and Home Premium editions.
2. In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)​
3. In the right pane, right click on Prevent changes to Taskbar and Start Menu Settings and click on Properties. (See screenshot above)​
4. To Enable Taskbar and Start Menu Properties
B) Go to step 6.​
5. To Disable Taskbar and Start Menu Properties
6. Close Local Group Policy Editor window. Your done.​
METHOD TWO
Using a REG File Download
NOTE: This method will work for all Vista versions.
1. To Enable Taskbar and Start Menu Properties
Enable_Taskbar_StartMenu_Properties.reg
download
B) Go to step 3.​
2. To Disable Taskbar and Start Menu Properties
A) Click on the sownload button below to download the file below.​
Disable_Taskbar_StartMenu_Properties.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
METHOD THREE
Manually in Registry Editor
1. Open the Start Menu.​
2. In the search box, type regedit and press Enter.​
3. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
Code:
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
B) Type NoSetTaskbar and press Enter.​
C) Right click on NoSetTaskbar and click on Modify. (See screenshot below)​
F) Go to step 7.​
6. To Enable Taskbar and Start Menu Properties
A) In the right pane, right click on NoSetTaskbar and click on Delete. (See screenshot above)​
7. Close regedit.​
  • Disable_Taskbar_StartMenu_Properties.reg
  • Enable_Taskbar_StartMenu_Properties.reg
dear shawn, i registered to this forum just to thank you SO MUCH for a wonderful explanation!!! i'm not sure how it happened (although i have an idea), but i had lost the ability to right click the start menu and task bar. i looked around trying to find info and yours was absolutely amazing. i have always wanted to edit something in registry but never had the oportunity or the knowhow. anyway, i tried the first method in group policy editor, which, in itself, was fun. i thought i might be able to do something there, but difficult to find it. anyway, there were 3 items that were disabled and i corrected them, but still had the problem. so i tried the registry method and saw that there were 4 entires that weren't shown in your screen shot. "no welcome window", "no task bar", "no start menu", and i think "no system tray" i deleted all of them so the window looked the same as your screen shot. and........i still had the problem :mad:!! i had rebooted after group policy edit to no avail, so i wasn't to confident that a reboot would work here either. needless to say that it did. oh by the way, i hope i'm not breaking any rules, but i don't have vista- my daughters' do. i'm still using xp and i loving it. thanx again and again. no way i ever would have solved this one. sincerely, eddie
You're most welcome Eddie, and welcome to Vista Forums. :)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
