Taskbar Toolbars - Disable Adding or Removing
How to Enable or Disable Adding and Removing Taskbar Toolbars in Vista and Windows 7
This will show you how to enable or disable the ability for all or specific users on the computer to add a new taskbar toolbar or remove a current taskbar toolbar in Vista and Windows 7.
If you want to enable or disable taskbar toolbars and remove all current Toolbars, then see: How to Enable or Disable Taskbar Toolbars in Vista instead.
If you want to add or remove taskbar Toolbars, then see: How to Add or Remove a Toolbar on the Taskbar in Vista
EXAMPLE: Toolbars Enabled and Disabled in Start Menu and Taskbar Properties
NOTE:
You can see this window by right clicking on the taskbar, Start menu button, or inside the Start menu and click on Properties.
EXAMPLE: Toolbars Enabled and Disabled in the Taskbar Right Click (Context) Menu
NOTE:
If Toolbars is missing and not grayed out, then see this link instead: How to Enable or Disable Taskbar Toolbars in Vista
OPTION ONE
2. In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)​
3. In the right pane, right click on Prevent users from adding or removing toolbars and click on Properties. (See screenshot above)​
4. To Enable Adding and Removing Taskbar Toolbars
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below 5A)​
NOTE: Not Configured is the default setting.​
B) Go to step 6.​
5. To Disable Adding and Removing Taskbar Toolbars
6. Close Local Group Policy Editor window.​
OPTION TWO
Using a REG File Download
NOTE: This option will affect all users on the computer.
1. To Enable Adding and Removing Taskbar Toolbars
NOTE: This is the default setting.​
Enable_Add-Remove_Taskbar_Toolbars.reg
download
B) Go to step 3.​
2. To Disable Adding and Removing Taskbar Toolbars
Disable_Add-Remove_Taskbar_Toolbars.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
OPTION THREE
Manually in Registry Editor
NOTE: This option will affect all users on the computer.​
1. Open the Start Menu.​
2. In the search box, type regedit, and press Enter.​
3. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
B) Type TaskbarNoAddRemoveToolbar and press Enter.​
C) Right click on TaskbarNoAddRemoveToolbar and click on Modify. (See screenshot below)​
F) Go to step 7.​
6. To Enable Adding and Removing Taskbar Toolbars
A) In the right pane, right click on TaskbarNoAddRemoveToolbar and click on Delete. (See screenshot above)​
7. Close regedit.​
  • Disable_Add-Remove_Taskbar_Toolbars.reg
  • Enable_Add-Remove_Taskbar_Toolbars.reg
