Security Center Specific Alert Notification
How to Disable or Enable a Specific Security Center Alert Notification in Vista
This will show you how to enable or disable the Security Center Alert Warning Notification for only UAC turned off, Firewall programs, Antivirus programs, and/or AntiSpyware (Ex: Windows Defender) programs. These are all enabled by default in Vista.
To enable or disable all Security Center Alert Warning Notifications, see: How to Disable or Enable the Security Center Alert Warning Notification in Vista instead.
This can be helpful if you would like to keep Security Center and the Security Center Alert Notifications enabled, but one of your security programs is giving you false alerts and you want to disable just that one alert.
If you disable the Security Center Alert Notifications for any one these type of programs, then you will not be alerted if it is out of date, turned off, or disabled. This tutorial will need to be done from within an administrator account to be able to do it.
EXAMPLE: Security Center Alert Warning Notification
OPTION ONE
For UAC Security Center Alerts
NOTE: This will enable or disable the Security Center alert when you turn off the UAC or elevate the administrator accounts UAC privilege level.
Using A REG File Download:
2. To Disable Only the UAC Alert
Disable_UAC_SecurityCenter_Alert.reg
download
B) Go to step 3.​
2. To Enable Only the UAC Alert
NOTE: This is the default setting.​
Enable_UAC_SecurityCenter_Alert.reg
download
B) Go to step 3.​
6. Log off and log on, or restart the computer to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
Manually in Registry Editor:
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5C)​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center
5. To Disable Only the UAC Alert
A) In the right pane, right click on a empty area and click on New and DWORD (32-but) Value. (See screenshot below)​
B) Type UacDisableNotify and press Enter.​
C) Right click on UacDisableNotify and click on Modify.​
F) Go to step 7.​
6. To Enable Only the UAC Alert
A) In the right pane, right click on UacDisableNotify and click on Delete. (See screenshot above)​
7. Close Regedit.​
8. Log off and log on, or restart the computer to apply changes.​
OPTION TWO
For AntiSpyware, Antivirus, and Firewall Security Center Alerts
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc
5. In the left pane, right click on Svc and click Permissions. (See screenshot above)​
6. Click on the Advanced button. (See screenshot below)​
7. Click on the Owner tab and click on your user account name listed under Change owner to to highlight it. Click on OK. (See screenshot below)​
NOTE: This is to take ownership of the Svc registry key by your user account to allow changes to made to the Svc key.​
8. Click on Users (your computer name) , at the top to highlight it, and check the Allow box for Full Control. Click on OK. (See screenshot below)​
NOTE: To see what your computer name is, see: How to Change the Computer Name in Vista.​
9. For AntiSpyware Programs Alerts
NOTE: This is Windows Defender by default in Vista, and any other installed 3rd party antispyware program that adds itself to the Security Center.​
A) In the right pane of Svc, right click on AntiSpywareOverride and click on Modify. (See screenshot below step 4)​
B) Go to step 12.​
10. For Antivirus Programs Alerts
NOTE: This will be any installed 3rd party antivirus program (Ex: Avast) that adds itself to the Security Center.​
A) In the right pane of Svc, right click on AntiVirusOverride and click on Modify. (See screenshot below step 4)​
B) Go to step 12.​
11. For Firewall Programs Alerts
NOTE: This is Windows Firewall by default in Vista, or any other installed 3rd party firewall program used instead that adds itself to the Security Center.​
A) In the right pane of Svc, right click on FirewallOverride and click on Modify. (See screenshot below step 4)​
12. To Enable the Security Center Alert
NOTE: For the type of program you selected in step 9, 10, or 11 above.​
A) Type 0 (number zero) and click on OK. (See screenshot below)​
B) Go to step 14.​
13. To Disable the Security Center Alert
A) Type 1 and click on OK. (See screenshot below)​
14. The registry will now look similar to this. (See screensot below)​
NOTE: I used AntiSpyware (step 9) programs for this example.​
15. Go back to step 9, 10, or 11 to enable or disable another Security Center Alert Notification for a program type.​
16. In the left pane, right click on Svc and click Permissions. (See screenshot below step 4)​
17. Click on Users (your computer name) , at the top to highlight it, and uncheck the Allow box for Full Control. Click on Apply, then on the Advanced button. (See screenshot below)​
18. Click on the Owner tab and click on the Other users or groups button. (See screenshot below)​
19. Type SYSTEM in the white box and click on OK. (See screenshot below)​
NOTE: This is the default owner of the Svc key in the registry.​
20. Under Change owner to, click on SYSTEM to highlight it and click on OK. (See screenshot below)​
21. Click on OK. (See screenshot below step 16)​
22. Close regedit.​
23. Log off and log on, or restart the computer to apply the changes.​
  • Disable_UAC_SecurityCenter_Alert.reg
  • Enable_UAC_SecurityCenter_Alert.reg
hi shawn..
i've tried what you said
but the warning just wont go off:cry:
and by the way, my windows became no sound!
help me...
i've tried your *other* tutorials but it just wont work...
and by the way..after i've tried the tutorial above... (and restarted)
my system became muted...
very confused now..
    T7250 2.0GHz
    2GB
    Intel GMA
    120GB Hitachi
Hi Vectorman,
What specific Security Center alert did you want to disable?
You can disable all of the Security Center alerts with this tutorial:
(Is this the other one you have tried already?)
http://www.vistax64.com/tutorials/90525-security-center-alert-warning-notification.html
This has nothing to do with your audio being muted though. Click on the speaker icon in the right corner of the taskbar and check to make sure that the Mute button under the slider does not have a red circle with a slash in it. If it does, just click on it again to unmute it. Check to make sure the volume slider is up high enough to hear. If none of this applied, then you may need to reinstall your audio driver.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
the above works great for the current user logged on. But I'm trying to disable security balloon pop-up for all users who log on after.
Hi Noanker,
Since the changes are in the HKLM key in the registry, it should apply to all users. You may need to restart the computer after applying the change in the registry for the other accounts to affected though.
I appreciate the tutorial, very helpful for the most part, but it doesn't say anything about disabiling notifications for Automatic Updates. I do of course run Windows Update manually regularly to keep updated but I prefer to do it manually so I have Automatic Updates turned off and thus want to keep Security Center from warning me all the time that Automatic Updates are turned off.
Thank you!
Hello Clh, and welcome to Vista Forums.
I found that the only easy way of doing this was to check the Check for updates but let me choose whether to download and install them option in the Windows Update settings. This way Windows Updates will not automatically install, and you will not get a Security Center warning.
