Vista - System Restore Task - Change Automatic Restore Point Schedule
Comment
Old 07-22-2008
Brink
How to Change the Automatic System Restore Point Settings in Vista Task Scheduler
Old 12-03-2008
Brink
Re: System Restore Task - Change Automatic Restore Point Schedule
Hi Bennys,
In Option Two (step 12), you can change it to be something other than Daily (ex: Weekly), or change the recur every (how many days) instead.
Old 12-04-2008
bennys
window vista
Thanks for your help once again. That wasn't as bad as I thought it would be.
Old 12-04-2008
Jim R
Vista Ultimate x86
I pretty much leave it alone but have changed the amount of drive space allowed for Windows to use for Restore Points.
Jim
Old 12-04-2008
Brink
You're welcome Bennys. I'm happy to hear that you got it sorted.
Old 04-02-2009
superneat
Vista Home Premium 32bit
thanks again!
Old 04-02-2009
Brink
You're welcome Superneat.
Old 05-02-2009
oondric
uhm.. help please
the Restore thing isnt there --;
Old 05-02-2009
Brink
Hello Oondric,
You have quite a few task folders missing there. Did you delete them?
Other than reinstalling Vista, you can see if doing a System Restore using a restore point dated when you thing they were still there. You might have to keep doing older restore points until you find one that they are there in afterwards.
Old 05-02-2009
oondric
lol.
thanks for the quick reply thar ;]
no. i didnt delete any folders. i reinstalled vista yesterday. i dont think system restore was installed with the vista i have. =\
no restore points have been made. even after before and after the installation of programs. i have tried to make restore points from the anitvirus program i'm using that automatically makes restore point before the clean up of the infected files/programs
an error comes up saying that the automatic system restore point option has been turned off. i have tried looking for the 'turn on automiatic system restore points' option but i cant find it.
heres a link to a thread that i have made.
Link:
Link to "A few missing .exe's"
thanks.
much appreciated for all your efforts ;]
Old 05-02-2009
Brink
I say that you may have a bad installation of Vista. You might consider formatting and doing a clean install of Vista to see if runs better this time.
Comment
Tutorial Tools
Tutorial Category
System Restore error (create restore point), event ID: 8193 Vista General
System Restore Not Saving Restore Point Vista General
System restore hasn't held a restore point since I installed Vista Vista General
How do I schedule system restore? Vista General
system restore (automatic daily restore points) Vista General
