| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | System Restore Task - Change Automatic Restore Point Schedule How to Change the Automatic System Restore Point Settings in Vista Task Scheduler Last edited by Brink; 05-07-2009 at 04:28 PM.. |
| Vista Home Premium 32bit | Re: System Restore Task - Change Automatic Restore Point Schedule lol. thanks for the fast reply again o-o i've reinstalled vista a few times within the last week. (4+?) and most of mai drivers uninstall themselves when i install vista. |
| Vista Ultimate 32bit | Re: System Restore Task - Change Automatic Restore Point Schedule Hello Shawn! You directed me here from the System Restore Tutorial. I followed all steps in this tutorial but still can't figure out how to extend the time the restore points are saved from 1 day(current) to 4-5 days period. I'm not being very clear with my wordings. Sorry. What I mean is presently, SR only allow me to choose the restore points from today. What if I want to select yesterday's restore point? What must I do? Thanks. how can i select last month restore point instead of last 5 days? thanks.. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Task - Change Automatic Restore Point Schedule Hello IonVista, and welcome to Vista Forums. This is not the same issue Benny was having though. Benny wanted to know how to set the amount of days for the task to save them instead. To select an older restore point to use to do a System Restore, you would select the "Older than 5 days...." option (if available) to see them. From there, you would select the restore point with the date that you wanted. Keep in mind though that restore points are only store up to 90 days, and when the max storage space has ran out the older restore points will be deleted to make room for the new one. Hope this helps, Shawn |
| Vista Ultimate 32bit | Re: System Restore Task - Change Automatic Restore Point Schedule then how can i select the restore point that was made more than 1 week ago? anyway thanks for the fast reply... |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Task - Change Automatic Restore Point Schedule If the option is not there from my post above, then it may have been deleted and you will not be able to select it. |
| home premium x64 | Re: System Restore Task - Change Automatic Restore Point Schedule I setup the Task Scheduler according to your tutorial to create a couple of restore points each day. The Task Scheduler History tab tells me that the actions are being carried out as scheduled. However, when I check the System Restore listing of restore points that have been created, usually only one restore point each day is recorded there. I have looked at all the options in the Task Scheduler to ensure that everything is enabled properly and all the Triggers are present and all looks good, and as I mentioned, the Task Scheduler History tab shows the scheduled actions are being carried out. So, I'm curious, why am I not seeing all of the scheduled Restore Points in System Restore? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Task - Change Automatic Restore Point Schedule Hell Travelin, and welcome to Vista Forums. Using these tasks, a system restore point will only be created when the task is scheduled if Vista detects a change in your system. However, you can create a new task to run a program instead for when you like. The program can be the Create Instant Restore Point shortcut. It will create a new restore point everytime it runs, no matter if there was a change or not to your system. Hope this helps, Shawn |
| home premium x64 | Re: System Restore Task - Change Automatic Restore Point Schedule Hello Shawn, Thanks for the explanation. I assumed that using the Task Scheduler to create Restore Points would be the equivalent of manually creating a restore point. If I understand your reply correctly, the Task Scheduler will not actually create the restore point unless there is a change to the system, but, won't this happen after the change to the system, not before? Paul |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Task - Change Automatic Restore Point Schedule If you create a new task using the shortcut above, then it is the same as creating a restore point manually, but only having it done automatically for you instead by the new task. The default System Restore tasks only create a restore point if it detects a change when that task runs at it's scheduled time. Yes, the change would have had to happen before the default tasks runs for it to create the restore point though. |
| home premium x64 | Re: System Restore Task - Change Automatic Restore Point Schedule Thanks, puzzling though. I thought the point of using the Task Scheduler to create restore points is to have restore points created on a schedule whether or not there have been changes to the system. I am working on the shortcut you suggested, but my preference is to have the Task Scheduler automatically create restore points for me on a set schedule even if there are no changes to the system. From your reply, I guess that's not possible. Thanks, Paul |
| Tutorial Tools | |
| Tutorial | Category | |||
| System Restore error (create restore point), event ID: 8193 | Vista General | |||
| System Restore Not Saving Restore Point | Vista General | |||
| System restore hasn't held a restore point since I installed Vista | Vista General | |||
| How do I schedule system restore? | Vista General | |||
| system restore (automatic daily restore points) | Vista General | |||
