Previous Versions Tab - Restore or Remove from Properties
How to Add or Remove "Previous Versions" Tab from Properties
This will allow you to add or remove the Previous Versions tab from all Properties pages of files and folders for all users in Vista and Windows 7.
Previous Versions is only available in the Vista Ultimate, Business, and Enterprise editions.
Previous Versions is available in all Windows 7 editions.
Previous Versions Requirements
  • Turn on System Protection for the drive(s) that you want to have previous versions of it's files and folders available.
  • Have any files that are not system files you want to also have previous versions of included in Windows Backups when created.
  • Volume Shadow Copy - Service set as default of Manual.
  • Server - Service set as default of Started and Automatic.
  • TCP/IP NetBios Helper - Service set as default of Started and Automatic.
  • Workstation - Service set as default of Started and Automatic.
EXAMPLE: Previous Versions Tab before and after Removed from Properties
1. To Remove "Previous Versions" Tab from Properties
Remove_Previous_Versions_Properties_Tab.reg
download
B) Go to step 3.​
2. To Restore Previous Versions Tab to Properties
Restore_Previous_Versions_Properties_Tab.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
  • Remove_Previous_Versions_Properties_Tab.reg
  • Restore_Previous_Versions_Properties_Tab.reg
