New Shortcut Fix
How to Restore the New Shortcut Context Menu Item in Vista
If when you right click on the desktop or in a User folder and click on New and Shortcut it does not work, then this will show you how to fix and restore the Shortcut menu item so it will create a new shortcut again.
EXAMPLE: New Shortcut in the Context Menu
NOTE:
You will only see this context menu item when you right click on a empty space on the desktop and in a nonsystem folder (Ex: C:\Users) Windows Explorer window. If you right on a empty space in a system folder (Ex: C:\Program Files, C:\Windows, etc...} Windows Explorer window, you will only see Folder in the New menu.
1. Click on the Download button below to download the file below to your desktop.​
New_Shortcut_Fix.reg
download
2. Right click on the downloaded .reg file and click on Merge.​
3. Click on Run, Continue, Yes, OK if prompted.​
4. Log off and log on, or restart the computer to apply the fix.​
5. When done, you can delete the downloaded .reg if you like.​
NOTE: If the problem still persists, then do a System Restore using a restore point dated before the problem.
  • New_Shortcut_Fix.reg
Thanks for this wonderful thread. I wonder if there is a way to remove New > Shortcut from context menu permanently. I think this function is unnecessary.
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    Microsoft Comfort Curve
    MX Revolution
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
I clicked on the link you've posted, but this is not a direct answer to my request. I want to remove "Shortcut" from "New" menu. Because this function is needless and annoying if you click on it instead of "Folder" by mistake.
Edit:
I've tried to change ".lnk" (ShellNew to ShellOld) from "HKEY_CLASSES_ROOT". It works well on Vista, but it does not work in XP. I know this is a Vista forum but i guess it would work for XP, too. (I'm using XP Professional on VMware due to the compatibility problems of some important programs.)
Thanks for your post.
The tutorial link posted by Gary is the answer to your request.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Hi gixkings,
To remove 'shortcut' from the new menu. Follow the directions at the above link. Use 'Option One', 'step 8'. The file extension you want to remove is .lnk.
Worked for me.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
Was wondering if somebody could help me. I have tried the .reg file posted but I still cannot use the New > Shortcut menu. When I select New Shortcut nothing happens.
Does anybody have any ideas?
Thank you!
    Dell XPS M1530 Laptop
    Intel Mobile Core2Duo T8100 2.1GHz
    Dell 0R387D (Intel PM965 Chipset)
    2x1GB PC2-5300 333MHz (Samsung)
    nVIDIA GeForce 8600M GT 256MB
    SigmaTel HD Audo
    Fujitsu 160GB 7200RPM (Free Fall Sensor)
    "Up to" 8Mbit (Typically 4 - 5)
    Windows Experience Index = 5.0
Hello FiRe5tOrM, and welcome to Vista Forums.
I have updated the reg file download. Please redownload it and give the new one a try to see if may fix it for you afterwards.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thank you! :D That works a treat. Greatly appreciated !
Edit: And such a quick response btw, very impressed. Thanks again!
    SigmaTel HD Audo
You're most welcome FiRe5tOrM. I'm happy to hear it is working now. :)
THANK YOU!!! I googled for a solution to this but everyone else is supplying time-consuming steps to try in addition to reinstalling Vista, etc. I'm glad I didn't try any of those before I saw this link. This worked perfectly, thanks again!
You're most welcome Dreemsnake. :)
