Customer Experience Improvement Program
How to Join or Unjoin the Vista Customer Experience Improvement Program
This will show you how to join or unjoin the Windows Customer Experience Improvement Program (CEIP) in Windows Vista.
The Windows Customer Experience Improvement Program (CEIP) in Windows Vista is a completely voluntary program designed to help Microsoft improve its operating systems over time. This program collects information about computer hardware and how people use Windows Vista, without interrupting the users in their tasks at the computer. The information that is collected helps Microsoft identify which Windows features to improve. The Windows Customer Experience Improvement Program runs only if an administrator chooses to participate.
For more about CEIP, see: Windows Customer Experience Improvement Program and Resulting Internet Communication in Windows Vista and Windows Vista Privacy Notice Highlights
STEP ONE
Join or Unjoin Vista Customer Experience Improvement Program
1. Open the Control Panel (Classic View).​
2. Click on the Problem Reports and Solutions icon.​
NOTE: If you have Problem Reports and Solutions turned off, then click on Close in the pop-up dialog box. (See screenshot below) If not, then you will not see this.
3. Click on the Customer Experience Improvement Settings link in the lower left corner. (See screenshot below)​
4. To Join the Customer Experience Improvement Program
A) Dot Join the Windows Customer Experience Improvement Program. (See screenshot below step 6)​
B) Go to step 6.​
5. To Unjoin the Customer Experience Improvement Program
NOTE: This is the default setting.​
A) Dot I don't want to join the program at this time.​
6. Click on OK.​
7. Click on Continue in the UAC prompt.​
8. Close the Problem Reports and Solutions window. (See screenshot below step 3)​
STEP TWO
Enable or Disable Tasks for Customer Experience Improvement Program
1. Open the Start Menu.​
A) In the white line (Start Search) area, type taskschd.msc and press Enter.​
B) Go to step 3 in Step Two.​
OR
2. Open the Control Panel (Classic view).​
A) Click on the Administrative Tools Icon.​
B) Click on Task Scheduler.​
3. Click on Continue in the UAC Prompt.​
4. In the left pane click on the arrow to the left of the Task Scheduler Library, Microsoft, and Windows folders to expand them. (See screenshot below step 8)​
5. In the left pane click on the Customer Experience Improvement Program folder to open it in the middle pane.​
6. To Enable the Tasks
NOTE: Only do this option if you Joined the Customer Experience Improvement Program in Step One (step 4) above. By default these task are enable in Vista.​
A) In the middle pane, right click on Consilidator and click on Enable. (See screenshot below step 8)​
B) In the middle pane, right click on OptinNotification and click on Enable.​
C) Go to step 8.​
7. To Disable the Tasks
NOTE: Only do this option if you Unjoined the Customer Experience Improvement Program in Step One (step 5) above. By default these task are enable in Vista.​
A) In the middle pane, right click on Consilidator and click on Disable. (See screenshot below step 8)​
B) In the middle pane, right click on OptinNotification and click on Disable.​
8. Close Task Scheduler.​
It's nice to find the options to join or unjoin these metric gathering services, but Vista continues to run tasks to gather data anyway!! I've found the spot in Scheduled Tasks to disable the stuff for Customer Experience stat gathering. I've had this machine running Vista Home Premium 32 bit since April 2007 and I'm still turning stuff off that runs my HD!! If I look at Process Monitor there's all these File Open, File Close, File Create stuff going on for no reason. Sometimes my HD will run constantly for 15 or 20 minutes and that's with Superfetch service not running!! It's pretty annoying!
Some people say it doesn't hurt your drive to have it doing all this stuff I don't care about, but it sure trashes system buffers!!! How about optimizing for stuff I want to do? I mean, I'm the one that forked out the $$$ for this PC, you know? Seems like I'll still be hunting this stuff down when SP4 comes out!! :(
Since I mentioned turning those off I might as well describe how I did it:
To turn off
Consolidator and OptinNotification
Go into Task Scheduler(make sure in the View Menu click Show Hidden Tasks)
Task Scheduler Library => Microsoft => Windows => Customer Experience Improvement Program.
Right click Consolidator and click Disabled
Right click OptinNotification and click Disabled
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Thank you MilesAhead. That would make a great addition to the tutorial.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
You're welcome. If I find any more clues how to quiet the HD in Vista I'll post 'em. :)
I sure would like to know what keeps touching all my files though. Every time I think I've turned it off, after a few days the same behavior starts up again. Very frustrating! :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
