Vista - USB Bootable Vista Installation Flash Thumb Drive
Comment
Old 09-17-2008
Brink
How to Create a Vista Installation USB Key
Old 09-27-2008
Brink
Re: USB Bootable Vista Installation Flash Thumb Drive
Quote  Quote: Originally Posted by Dwarf View Post
Hi Shawn,
Another question. If the USB flash drive is of sufficient capacity, say 8GB, can you add another folder to it after you have followed the procedure in your Tutorial? I would like to create a folder called 'Vista Support', and I would keep this folder updated with the latest drivers so that when it comes to reinstallation, everything would be in one place. Could I also place RAID drivers in this folder (assuming that I can locate them) and use them during the initial installation of Vista if the necessary drivers aren't included with Vista itself. It would also be useful to have other programs on there as well, such as Adobe Reader and possibly Microsoft Office 2007 with SP1, together with other documents, information and files. Is this possible or not?
Oh yes absolutely. Great idea, but you would still have to manually install them after Vista of course.
I will add a TIP box for this to the tutorial.
Old 09-29-2008
ripbox
vista ultamate 64bit
Superb Tutorial... and that fact that all the drivers can also be stored on the flash drive too will save a shed load of time on my next format... when i stop being lazy... lol
Edit: can you add a little piece on how to data write protect the USB key to prevent accidental formatting
Old 09-29-2008
Brink
You're welcome Ripbox.
I'm not sure about how to go about that so that the USB key will be write protected for any computer it is plugged into.
Old 09-30-2008
ripbox
No im not sure my self.... i do here there are usb key that have a write protect switch like the old floppy discs but are limited to a select few...
mind you i did google up this and it sound ok maybe you can check it out and tell us what you opinion is of it
Write Protect (Read only) Your USB Drive with USB Write Protector | Shivaranjan.com
Old 09-30-2008
Brink
Unfortunately, it only prevents the computer you install it on unable to write to the USB drive and not write protect the USB drive itself. Plus, you can easily edit the registry for this without having to install a 3rd party program.
If you like I can create a tutorial on this, but without the USB drive itself being write protected, I do not see much need for it.
Old 09-30-2008
ripbox
Np brink... i can always make some other backup... i only asked because sometimes i have my blonde moments and end up deleting things i had no intention of deleting
And i wasn't sure of how to protect data stored on a flash drive... no big ussue though
I'm in need of a larger USB stick so ill look for 1 with the protetion switch on
Edit: 1 more thing... Is there a way to embed your/my serial key into the USB stick so that i/we don't have to enter it on install?
Old 09-30-2008
Brink
There is a way using vLite with the Unattended button. I have not done this myself, so I'm not sure on how to do it. You might post this in the General Discussion forum to see if someone knows how for you.
Old 10-07-2008
kfm
Vista Home Premium 32bit
thanx for your help
i get "the system can not find the path specified " after step 21
plz i need your help coz it is important to me to have this bootable usb flash
note my usb flash (8GB) come with u3 application preinstalled ...
also i formated the drive from windows vista home premium32 and second time using your reply cmd
for another user here ....
Code:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>diskpart
Microsoft DiskPart version 6.0.6001
Copyright (C) 1999-2007 Microsoft Corporation.
On computer: KOTEIBA-PC
DISKPART> list volume
Volume ### Ltr Label Fs Type Size Status Info
Volume 0 D 11 CDFS DVD-ROM 4658 MB Healthy
Volume 1 C NTFS Partition 99 GB Healthy System
Volume 2 F New Volume NTFS Partition 29 GB Healthy
Volume 3 G NTFS Partition 29 GB Healthy
Volume 4 H New Volume NTFS Partition 29 GB Healthy
Volume 5 E FAT32 Removable 7666 MB Healthy
DISKPART> select volume 5
Volume 5 is the selected volume.
DISKPART> active
DiskPart marked the current partition as active.
DISKPART> exit
Leaving DiskPart...
C:\Windows\system32>cd\
C:\>D:\boot\bootsect.exe/nt60 E:
The system cannot find the path specified.
C:\>
Old 10-07-2008
kfm
update
i used a recovery dvd from hp which has windows vista home premium
and i guess it has no bootsect.exe on it
.... so any other idea about how to make it
bootable on my usb flash drive
thanx
Old 10-07-2008
Brink
Hello kfm, and welcome to Vista Forums.
Are you using a retail Vista installtion DVD?
Do you have more than one partition on the USB flash drive?
The reply link will change the drive letter again. Do the list volume command again to see if the USB flash drive letter is now different than the E: you have used in the command.
Comment
Tutorial Tools
Tutorial Category
USB flash drive installation Vista installation & setup
Problem with San Disk thumb drive and vista General Discussion
bootable thumb drive General Discussion
Vista cannot bootup when USB thumb drive is plugged in Vista hardware & devices
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
