Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Vista - USB Bootable Vista Installation Flash Thumb Drive
Comment
09-17-2008
Brink
Vista x64 Ultimate SP2, Windows 7 Ultimate x64 SP1
Texas, USA
How to Create a Vista Installation USB Key
10-07-2008
Brink
Texas, USA
Re: USB Bootable Vista Installation Flash Thumb Drive
Quote: Originally Posted by kfm View Post
update
i used a recovery dvd from hp which has windows vista home premium
and i guess it has no bootsect.exe on it
.... so any other idea about how to make it
bootable on my usb flash drive
thanx
That would be why then. It must be a retail Vista installation DVD for it to have the bootsect.exe file.
You can borrow a friends retail Vista installation DVD to use to create this though.
10-07-2008
kfm
Vista Home Premium 32bit
sweden
i just did that from another windows vista cd .. but my question now is it possible to copy original recovery dvd contents on the usb after i created this bootsect.exe from my friend vista cd
thanx
10-07-2008
Brink
Texas, USA
Sorry, but no.
10-08-2008
kfm
sweden
thanx again and sorry for me again ...as you know most laptops now come with recovery cd not a retail vista cd .. so can i make an image of hp recovery cd and then make it bootable on the flash drive..any help appreciated
coz i suffer alot with recovery sets (either lost,scratched ...etc)
10-08-2008
Brink
Texas, USA
I'm sorry kfm, but I do not know how to do it for a OEM recovery CD.
You might post this question in the General Discussion forum to see if by chance someone may know of a way to create a bootable USB flash drive with a OEM Vista recovery CD.
10-11-2008
hclarkjr
Vista ultimate 64 bit SP2
EXCELLENT GUIDE!!!! many thanx to you Brink just created install DVD with vlite and integrated all the updates till now for vista with sp1. worked great
10-11-2008
Brink
Texas, USA
You're welcome H.ClarckJR.
10-17-2008
dinesh
Windows 7 RTM 64-bit
India
hey shawn, i got the same error message like UndeFinitiOn. i also tried the next step that you provided. it still gives the same error, no partition selected.
10-17-2008
Brink
Texas, USA
Hi Dinesh,
Do you have a retail Vista installation DVD to use?
If so, did you try these steps with the tutorial instead?
10-20-2008
dinesh
India
No Shawn, i do not have a retail vista installation disk. I have installed the OEM vista OS (cracked). May be this is the reason for this issue. Anyways, thanks for the help dear. . .
Comment
 USB Bootable Vista Installation Flash Thumb Drive problems?
Tutorial Tools
Similar topics to: USB Bootable Vista Installation Flash Thumb Drive
Tutorial Category
USB Flash Drive Installation Kits Vista General
USB flash drive installation Vista installation & setup
Problem with San Disk thumb drive and vista General Discussion
bootable thumb drive General Discussion
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
