Elevated Command Prompt
How to Open a Elevated Command Prompt in Vista
This will show you how to open a elevated command prompt with administrator rights (Run as administrator) instead of the default command prompt without administrator rights.
The cmd.exe file for the command prompt is located at C:\Windows\System32\cmd.exe
EXAMPLE: The Default Command Prompt (top) and the Elevated Command Prompt (bottom)
NOTE:
Notice how the elevated command prompt opens to the C:\Windows\System32 location instead of just the current users C:\Users\(User Name) location.
1. Open the Start Menu.​
2. Click on All Programs and Accessories. (See screenshots below)​
3. Right click on Command Prompt and click Run as administrator.​
OR
2. In the white line (Start Search) area, type cmd
3. Press CTRL+SHIFT+ENTER.​
OR
3. Right click on cmd (at top), and click on Run as administrator. (See screenshot below)​
NOTE: To open a regular non-elevated command prompt window, just click on cmd instead.
