Compatibility Properties Tab - Restore or Remove
How to Restore or Remove the "Compatibilty" Tab in Vista
This will show you how to restore or remove the Compatibility tab in the Properties window of all folders, files, shortcuts, and drives for all users on the computer. By default, the Compatibility tab is displayed in Properties.
If the methods below do not help in restoring the Compatibility tab, then run the sfc /scannow command to repair the C:\Windows\System32\wer.dll and C:\Windows\System32\faultrep.dll files.
EXAMPLE: Compatibility tab Before and After removed from Properties
METHOD ONE
Through Local Group Policy Editor
2. In the left pane, click on Computer Configuration, Administrative Templates, Windows Components, and Application Compatibility. (See screenshot below)​
3. In the right pane, right click on Remove Program Compatibility Property Page and click on Properties. (See screenshot above)​
4. To Restore the Compatiblity Tab
B) Go to step 6.​
5. To Remove the Compatiblity Tab -
METHOD TWO
Using a REG File Download
1. To Restore the Compatiblity Tab
Restore_Compatibility_Tab.reg
download
B) Go to step 3.​
2. To Remove the Compatiblity Tab
Remove_Compatibility_Tab.reg
download
METHOD THREE
Manually in Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If promped by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. In regedit, navigate to the location below. (See screenshot below)​
NOTE: If AppCompat is not there, then right click on Windows and click on New and Key. Type AppCompat and press Enter.​
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\AppCompat
4. To Remove the Compatiblity Tab
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
B) Type DisablePropPage and press Enter. (See screenshot below)​
C) Right click on DisablePropPage and click on Modify.​
F) Go to step 6.​
5. To Restore the Compatiblity Tab
A) In the right pane, right click on DisablePropPage and click on Delete. (See screenshot above)​
B) Click on Yes to confirm the deletion.​
6. Close regedit.​
  • Remove_Compatibility_tab.reg
  • Restore_Compatibility_tab.reg
I followed both Method 2 and Method 3 and compatability tabs were not restored in my Windows Media Player or Windows DVD Maker (I don't know where else to look for compatability tabs). I need the compatability tabs to be there so I can change the audio filters. My problem is that I can burn a video dvd that will play in my dvd player, but no audio plays. If I play the dvd on the pc it plays audio. I have burned dvds in WMP, WDM and my sony and canon programs. Only the WDM dvd played video only in other dvd player, the others didn't work at all. I am using DVD+R discs. I do not have any extra codecs programs (although I did add the Vista Codecs 64x Package). It is probably obvious to you, but I do not know much about computers, I only follow instructions online. Please advise me. Thank you.
    Gateway
Hello Slh134, and welcome to Vista Forums.
Compatibility Mode is for 3rd party programs and not for Windows system files like WMP or WDM. The options for Compatibilty Mode are grayed out for system files, so you would not be able to change them anyways. :(
You should go ahead and post your issue with the codecs, playing video and audio in the Media Center forum area to see if we may be able to help better with it.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
