File Menu - Restore or Remove
How to Restore or Remove "File" from the Windows Explorer Menu Bar
This will show you how to restore or remove File from the Menu bar in Windows Explorer and Internet Explorer for all users in Windows 7 and Vista.
You will need to have the Menu bar enabled to be able to see the File menu item.
EXAMPLE: Windows Explorer Menu bar with File Restored and Removed
METHOD ONE
2. In the left pane, click on User Configuration, Administrative Templates, Windows Components, and Windows Explorer. (See screenshot below)​
3. In the right pane, right click on Remove File menu from Winodows Explorer and click on Properties. (See screenshot above)​
4. To Restore File Menu
B) Go to step 6.​
5. To Remove File Menu
METHOD TWO
Using a REG File Download
1. To Restore File Menu
Restore_File_Menu.reg
download
B) Go to step 3.​
2. To Remove File Menu
Remove_File_Menu.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then on OK when prompted.​
6. When done, you can delete the .reg file (On Desktop).​
METHOD THREE
Manually in Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
3. In regedit, go to: (See screenshot below)​
4. To Remove File Menu
A) In the right pane, right click on a empty area and click on New and on DWORD (32-bit) Value. (See screenshot above)​
B) Type NoFileMenu and press Enter.​
C) Right click on NoFileMenu and click on Modify. (See screenshot below)​
D) Type 1 and click OK. (See screenshot below)​
F) Go to step 6.​
5. To Restore File Menu
A) In the right pane, right click on NoFileMenu and click on Delete. (See screenshot above)​
6. Close regedit.​
  • Remove_File_Menu.reg
  • Restore_File_Menu.reg
