Mystify Screen Saver - Customize Settings
How to Customize the Vista Mystify Screen Saver Settings
By default the Mystify screen saver has no options to set in the Screen Saver Settings window. However, you can customize the Mystify screen saver settings through the registry instead. This will show you how to.
The default location of the Mystify screen saver file is at:
C:\Windows\System32\Mystify.scr.
You will just need to play with the settings and adjust the Value Data (step 8) until you get the desired affect from the selected DWORD Value Name (step 5).
EXAMPLE: Mystify Screen Saver
OPTION ONE
To Restore the Default Mystify Settings
Restore_Default_Mystify.reg
download
2. Click on Save, and save the .reg file to the Desktop.​
3. Right click on the download .reg file and click on Merge.​
4. Click on Run, Continue (UAC), Yes, and then OK when prompted.​
5. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
To Customize the Mystify Settings
1. Open the Start Menu.​
Code:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Current
Version\Screensavers\Mystify
5. In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
6. Type in a DWORD Value Name you want in the table below and press Enter.​
DWORD Value Name
Value Data
Description
Blur
0 or 1
For line fade away. Set this value to 1 to enable, 0 to disable and let them draw on top of each other.
LineWidth
1000000000 to 1080000000
For thinner or thicker lines. Higher value number for thicker lines.
NumLines
1 to 100
For more or less lines on screen. Higher value number for more lines.
7. Right click on the DWORD Value Name (from step 6) and click on Modify.​
8. Dot Decimal, and type in the Value Data you want in the table above and click on OK. (See example screenshot below)​
9. Repeat steps 5 to 8 to customize another available DWORD Value Name option.​
NOTE: You can add and customize one, a few, or all of the available options if you like (see table below step 6), but only add one instance of each DWORD Value Name in step 5 to prevent problems.​
10. Close Regedit when done.​
  • Restore_Default_Mystify.reg
