Vista - System Recovery Options
Comment
Old 11-26-2008
Brink
How to Boot to the System Recovery Options in Vista
Old 12-03-2008
bennys
window vista
Re: System Recovery Options
Ahhhh...got it.
Thanks.
Old 12-03-2008
Brink
You're welcome Bennys.
Old 01-08-2009
Overclock2much
Ultimate x64 SP1
Thx for the tutorial on this. I wasn't getting any O/S listing in the System Recovery Box. glad you cleared that up for me.
How long does this process take?
It says it might several minutes but it's been going on for almost 30 min. I guess if the O/S is really screwed up it might take several hrs.
Old 01-08-2009
Brink
Hello Overclock2much,
It really depends on the option you choose and what all is wrong for how long it will take. Plus, how large the hard drive is and how much is saved on it. I would not think that it would take several hours though unless you have some serious corruption problems.
Old 03-05-2009
MWB
Vista Business x64
Red face Re: System Recovery Options
Hi Shawn
I am new writer looking to resolve a partial crash of Vista business.
I have read your "recovery" tutorial but think mine may be disabled and don't want to dabble before I know a bit more!
I am using a compaq 6715b with preloaded vista and have no back up discs.
Following use of a Reg Clean from Regsoft I have lost linkage and set up options to numerous areas including printer, modem, Control Panel, and my windows shadow recovery is not accessible showing erroe 0x81000202 and neither is the HP recovery option for a timepoint. The update function is not working and my Vista software is not validating (error 0x80070426) but my Office software is and is functioning normally.
The system is still up and semi-functional and I can now access my modem by cable but not wireless.
Any direct advice or next steps/contacts I could take?
Kind Regards
Mark
Old 03-05-2009
SIW2
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Hi MWB,
Registry cleaners can be dangerous- if you use one, it is best to check the entries it offers, before removing them.
I am not familiar with regclean , but if you are able to open the program , you will probably find it backed up the entries it removed and can restore them for you.
Otherwise, if you browse to the regclean install files folder, probably in Program files (x86) there will likely be backups there in the form of .reg files.
Double click on those and they will merge back into the registry - you will get a warning it is dangerous to merge files- but under the circumstances, I would do it.
If you are not able to open Regclean directly, type C: in the start search box and Program Files (x86) should pop up. Alternatively, type Regclean in the start search box - when it pops up, rt click and select Open file Location - there will be a folder called Data or Backups, or similar, containing the .reg files.
Will Look like this :
Hope it helps
SIW2
Old 03-05-2009
MWB
Vista Business x64
Quote  Quote: Originally Posted by SIW2 View Post
Hi MWB,
Attachment 10548
Hope it helps
SIW2
Hi SIW2
Many thanks for the support and advice.
The software I used was regpair v1.8 from regsofts.com and was a recommended download from Cnet. Not being aware of the dangers you've highlighted I ran a full scan and full fix twice in a row without checking the detail before restarting and subsequently losing OS functionallity. I did immediately go back and restore both of the "fixes" from within the registry cleaner but to no avail. I have followed your suggested process and the back up files are there but are empty presumably because of previusly running the restore process.
I am awaiting feedback from Regsofts and Microsoft but am open to any good advice which could avoid me having to run a full PC restoration.
Many Thanks
Mark
Old 03-05-2009
Brink
Hello Mark, and welcome to Vista Forums.
You might see if you can do a Vista System Restore using a restore point dated before this issue to see if it can fix it for you.
Old 03-05-2009
SIW2
Hi Mark,
Type services.msc in the start search box, click it when it pops up and make sure that Task Scheduler, Microsoft Shadow Copy provider and Volume Shadow Copy Service are all running.
Services
Then try System restore.
System Restore - How to
Hope it helps
SIW2
Old 03-06-2009
MWB
Vista Business x64
Quote  Quote: Originally Posted by Brink View Post
Thanks Shawn
When I access this option it says it is not available although I have used it once before some months ago without issue.
I checked the set up in services as per the default comment in your tutorial and it shows the volume shadow copy as not started and manual but when I do try to start it a pop up comment says Error 2 cannot find file? presumably this has been disabled in some way by the registry cleaner that I ran!
The HP recovery F drive has 8MB of data within it but the recovery option won't run and I unable to access the data helped in this partition. The E drive has over 1MB of OS Tools which I can access but don't know if or what I could usefully action.
Kind Regards
Mark
Comment
Tutorial Tools
Tutorial Category
How to creat recovery partition with recovery image in vista to restore the system Vista installation & setup
System Recovery Options Not Available Vista installation & setup
No operating systems in System recovery options Vista installation & setup
Data Recovery Options Vista General
Stuck in System Recovery Options Vista General
