Boot Priority - Change
How To Change the Drive Boot Priority in BIOS
This will show you, step by step, how to change the drive Boot priority on your computer in the BIOS.
This will set your computer to Boot from where you want, in any order.
You may want to view this Tutorial on another computer, as your computer will need to restart multiple times.
Starting Out:
1) Shut down your computer​
2) Power your computer back on, but be ready.​
3) The BIOS screen is the motherboard boot screen. This is NOT the operating system loading, this takes place before that. Generally, it will be a screen with the computer manufacturer logo, and a little bit of text. You will need to press a certain key at this point, and it varies depending on the motherboard maker, BIOS, and computer manufacturer. Generally, it is ESC, F1, or DEL. To check what yours is, look on the bottom of the BIOS boot screen, and it should show something like this:​
Down on the bottom, it should say "Press [key] to enter SETUP". Press that key, and let SETUP load.​
4) After the BIOS SETUP loads, you should see a screen similar to THIS:​
5) Scroll over to the BOOT menu using the Arrows Keys. It should automatically show the menu, but if not, then hit enter. This should bring up a menu like THIS:​
6) This is where it varies depending on the motherboard. Some will show the menu as it is shown below in the image, and others will have a secondary menu for the Boot order.​
7) Now just select where you want to boot from first, second, and third. It is simple if you follow the instructions in the BIOS screen.​
8) After the new order is set, press F10 to SAVE AND EXIT, or scroll over to the EXIT and select save changes. This will REBOOT your computer.​
9) The computer should now start up and load from the first boot device. If it is the CD/DVD Drive first, then it will appear to hang at a black screen with a white cursor.​
If there is no CD/DVD, then it will eventually move on, be patient. If there is a CD/DVD in the drive, then it will say: "Press any key to boot from CD..." Hit the key to load from the menu if that's what you need. If not, let it Boot normally.​
This procedure is used to change the BOOT order to allow a boot up from a CD/DVD or a different HDD. This is used to reinstall/install/repair an Operating System (i.e. Vista), or to boot from a different OS first.​
I hope my second Tutorial here helped you out!
~Lordbob
EDIT: I changed the format here, as well as added images of newer BIOS menus. Hope it helps you out!
HELP i have a hp a6042n and i cant get there. tried f8 and f1. havent tried esc. any idas?
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
thx i'll try imdeiatly
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
Sorry I couldn't show all the BIOS screens on here, there just wasn't room. I had to go with more generic BIOS screens, but I hope you guys can still get it figured out. ;)
Hope you guys liked the tutorial.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Tarantula
    Razer Lachesis
    not fast enough
u can use virtaul pc
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
Sorry Kiddieboy12, Virtual PC will not show the BIOS settings. :(
I wish it did though.
oh..
    ECS NETTLE
    3 gb
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    hp casing
    defult..
    hp
    hp
Thank You Sir it worked im scanning my computer now.
    Toshiba / Satelite A300-A305
    Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz 2.00GHz
    3.00 GB
It was really helpful, thanks. :)
Thank you so much for reminding me how to do this. I am trying to help a friend, still using windows, who is more P/C illiterate than I am. (And I'm a complete P/C illiterate!) Thanks again! I've been on linux for decades now, and I've forgotten so much about windows.
    Acer
    NVidia
    Asus
