Vista Tutorial - Hard drive speed boosts
Comment
Old 04-28-2007
Brink
Administrator
How to Increase Hard Drive Performance in Vista
Old 10-13-2007
syklitengutt
Vista
Re: Hard drive speed boosts
Tnx for this.
I will try to update the chipset and bios.
I usually use the computer with power cord, so Im not worried about loosing stuff. The only times I use it without powersuply is when I watch dvds.
Il try and come back to you.
Old 10-13-2007
syklitengutt
Vista
Ok. It didn't help at all. Still the same. I Check the boxes, and press ok, and when I open them, its the same again, still unchecked.
I have disabled UAC, can this make a difference?
Old 10-13-2007
Brink
Administrator
Chris,
I searched hi and low and you are not the only one with this problem. Everything points to the cause as the drives being on a Raid controller. If it is on a Raid controller, they say to adjust it from the Raid controller's settings instead. I have yet to find a solution for this if Raid is not the issue.
Sorry,
Old 10-13-2007
syklitengutt
Vista
this is proborli too much info but heres the everest log from windows storage.
Old 10-13-2007
Brink
Administrator
Chris,
I'm afraid this has me stomped to. I do not know what else to do to make it take the settings.
Old 11-22-2007
periboob
Vista Home Basic
I was eager to try this on my laptop, because I am connected to AC 98% of the time. But as reported by the other user, in my system the settings do not stick.
I can check the box by:
"Enable write caching on the disk"
But right below, it says
"This device does not allow its write cache setting to be modified"
All the other choices are grayed out.
This is a fairly new Dell, Maybe the newer ones, newer drivers, let you know that you cant change it, rather than just rejecting it..
Old 03-07-2008
amplid
Vlaming
Vista Ultimate x64
Hey,
How do I know wether I have a backup power supply? Mean, can I check it without opening my case?
Old 03-07-2008
Brink
Administrator
Hi amplid,
You would know if you had a backup UPS power supply box. It would be a separate box that plugs into your outlet, then you plug your computer into it. You can see more details on them here with a image of a example UPS box.
Uninterruptible power supply - Wikipedia, the free encyclopedia
and
APC - Back-UPS - Product Information
Old 03-07-2008
amplid
Vlaming
Vista Ultimate x64
Right, thanks!!
Old 03-07-2008
Brink
Administrator
Your welcome amplid.
Comment
Tutorial Tools
Tutorial Category
Hard drive light constantly flashing ,reading hard drive during id Vista hardware & devices
Crashed hard drive...copied hard drive but can't access User area Vista General
SATA & eSATA hard drive speed poor Vista hardware & devices
very slow hard drive write speed Vista hardware & devices
Transferring files from Slave XP hard drive to new Vista Hard drive - primary Vista installation & setup
