Security Center
How to Disable or Enable Security Center in Vista
Security Center alerts you when your security software is out of date, turned off, or when your security settings should be strengthened. Security Center monitors the following: Firewall, Automatic updating, Antivirus, Antispyware (EX: Windows Defender), Internet security settings, and UAC (User Account Control).
If you disable the Security Center, then you will not be alerted if something disables one of your security programs.
EXAMPLE: Security Center Disabled
STEP ONE
Security Center Alert Warning
1. If you are Disabling the Security Center
NOTE: You will need to do this before you Disable the Security Center in step 7 below.​
A) Turn off the Security Center alert warning notification.​
B) Go to STEP TWO below.​
2. If you are Enabling the Security Center
NOTE: You will only be able to do this after you enabled the Security Center in step 8 below.​
A) Turn on the Security Center alert warning notification if you want to.​
B) Continue to STEP TWO.​
STEP TWO
Through Services
3. Open the Start Menu.​
4. In the white line (Start Search) area, type services and press Enter.​
5. Click on Continue in the UAC prompt.​
6. Scroll down and right click on Security Center and click on Properties. (See screenshot below)​
7. To Disable Security Center
NOTE: Be sure to do step 1 above before you disable the Security Center.​
A) Click on the Stop button and wait a second for it to stop. (See screenshot below step 9)​
B) To the right of Startup type, click on the drop down menu arrowand select Disable. (See screenshot below step 9)​
C) Click on the Apply button.​
8. To Enable Security Center
NOTE: Be sure to do step 2 above after enabling the Security Center.​
A) To the right of Startup type, click on the drop down menu arrow and select Automatic. (See screenshot below step 9)​
B) Click on the Apply button.​
C) Click on the Start button.​
9. Click on OK.​
10. Close Services Window.​
With my computer I go to services and it has security accounts manager but does not have Security Center under it so how can I get that to show up so I can turn security center back on.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I am just doing the sfc/scannow and yes I had installed live one care. I have a norton 360 disc here do you think that is a better program. Also I think it is a virus that is doing this because I have had the shutdown removed,task manager and regedit.exe but I have fixed them up now it had happened with my previous vista installation but I did a clean install hopefully sfc/scannow can fix the problem and thanks for your help anyway
I would not use Norton with Vista. It has caused problems for a lot of people.
I think that Live OneCare may the one that removed it.
You did a clean install and the Security Center service is not there?
nah I had done a clean install just on the Saturday because I was setting up dual boot and I had security center running perfectly now the only thing that shows up under security center is the security center is turned off and the button to turn it on but it says its disabled when i press it, just yesterday I started getting a few problems happening. would u be able to recommend any better antivirus to use besides live one care. I will see scannow if it has fixed the problem I just have to reboot so I will be back in a few mins
I use the free Avast antivirus program and have not had any problems with it yet.
http://avast.com/eng/avast_4_home.html
If Live OneCare is still installed, then I think it will need to be uninstalled first.
If I do a install from the vista disc the one that keeps your files does that mean everything in the registry, such as games or programs would have to be reregistered and would it probably fix this problem
Yeah I cant get the Avast program I am over my download limit and it says it will take 2 hrs which the connection will probably drop out anyway. So how do you think I can get security center working again, if i uninstall live onecare I don't think that will put Security center properties back in so what can u suggest I do now
Because if I install the vista option which keeps your files I will ahev to re register the programs won't I ?
I would try uninstalling the Live OneCare first to see if that will return the Security Center service in Services. It will save you a lot of time if it does. You can always reinstall it.
Using the Repair install option will repair your Vista installation without losing your files, settings, and programs. Just backup anything you do not want to lose, like Favorites and email messages, just in case something goes wrong. I do not know if you will need to re-register the programs or not afterwards. If so, it should not take long to do.
Your welcome JamieMyHaven. Let us know how it went.
i got these kind of error message while trying to start the services.
Error1079: The account specified for this service is different from the account specified for other services running in the same process (Security Center) SBSD Security Center
Error1068: the dependency service or group failed to start. any clue to why is it like this? btw, i dont have the "Change the way security center blablabla..." instead, "Get the latest blablabla.." appears at the very bottom of my left pane. how is it like that? help me. i want the security center disabled and also the annoying red X shield notification to disappear every time windows start. thanks. ps: not that your guide is useless, but in my case that dont seem to help fix the problem. anyway, thanks for writing such guide. :)
    T7250 2.0GHz
    2GB
    Intel GMA
    120GB Hitachi
Hi vectorman,
Check these settings in Services:
1. Right click on the Security Center service and click Properties.
2. Click on the Log On tab.
3. Under Log on as:
A) Dot This account, and make sure it has Local Service in the field.
4. At the bottom, make sure that Undocked Profile is set to Enabled.
5. Click on the Recovery tab.
A) Make sure that Restart the Service is selected for the first and second failure.
6. Click OK.
See if that helps it now,
Hi vectorman,
3. Under Log on as:
6. Click OK.
Hi Brink, thansk for the reply. btw, thats not helping in my case though :( i've research for this security center stuff. and find out that you can disable this annoying red X shield on taskbar by renaming these files wscapi.dll wscsvc.dll wscui.cpl into .bak extension or anything that you desire (i had copied these files in other folder, backup)
    T7250 2.0GHz
    2GB
    Intel GMA
    120GB Hitachi
vectorman,
I'm glad that you found a way to resolve your problem. Just so you will know to prevent it from happening, since these are system files, they may get restored if you run any kind of System Restore or a sfc /scannow command.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thank you John for bringing that post to my attention. That was nice of Dumber to refer this tutorial.
i think i should use the old thread instead of creating a new thread.
my question is i've done my way of disabling the alert; red X balloon-like at the bottom taskbar tray.
but after i updated to vista Home premium SP1, i get back the alert... you know
i'd like to know is there any way to disable tthe alert besides renaming the three file
wscapi.dll
wscsvc.dll
wscui.cpl
TIA,
shenli
    T7250 2.0GHz
    2GB
    Intel GMA
    120GB Hitachi
