Vista - Index - Enable or Disable
Comment
Old 06-10-2007
Brink
How to Enable or Disable Search Index in Vista
Old 06-11-2008
MadDogAZ
Vista Ultimat 32bit
Re: Index - Enable or Disable
Quick question on this. I store my Outlook pst file on my local drive. Does this get indexed with this feature? The only real intense searches I do on my laptop are in my email. I'm thinking Outlook indexes/handles these searches, so turning off Vista's indexing still makes sense. Can you confirm?
Old 06-11-2008
Brink
Hi MadDogAZ,
Welcome to Vista Forums.
Outlook adds itself and uses the Index in Vista for it's searches, so turning it off will also turn it off in Outlook.
Old 06-19-2008
zebraloc
Vista Ultimate x64
Thanks for all your hard work, Brink. You make this Vista thing a better break from XP. Thanks again.
Old 06-19-2008
Brink
Your welcome Zebraloc, and welcome to Vista Forums.
Old 06-19-2008
Abiosis
Windows Vista® Ultimate x64 SP2 v.113 build 6002/W7 x64 7000
I found I've to do both methods to turn the Indexing off completely...
is that any error'll occur while turning off indexing & 0 page files?
please enlighten,thanks Shawn
Old 06-19-2008
Brink
Hi Abiosis,
It will not hurt anything by turning off (disabling) the Index.
Old 07-16-2008
neon.dead
Vista Ultimate x32 SP1
Is it correct that a lot of constant running of hard disk causes it to age off more quickly.
i recently lost a disk. my pc would not read it anymore so will turning off indexing improve h.disk life. I really need to know cause i have the torrent's running about 20 hours a day plus i don't have a ups.
Old 07-16-2008
Brink
Hi Neon.Dead,
It really depends on if you do a lot of searches or not and prefer the Index search or non-indexed search. It can help if you do not do a lot of searches. If you do, then the Index can help make doing searches quicker and not search the hard drive as long per search, but the results may not always be as acurate.
Old 07-16-2008
Rob Kuhn
Vista BE x64
Cool Re: Indexing Service (Search)
Quote  Quote: Originally Posted by Asky View Post
Thanks Man !
Kinda disliked the Indexing feature , Google Desktop is btter IMO
Google Desktop is not compatibile with the 64-bit version of Vista.
Old 07-21-2008
bmb
Vista Ultimate
Hi
I have one question about Indexing and Disabled it from my D drive( My Computer Right Click..as like Option 2 here shown) and i wants to disable it from C drive too if this helps for better Perfomance.But if i disable it.... i will get any Error message for this all the time ??Coz im littlebit worried one mentioned 1000 error ..thats why..
And if i disable from Service windows search what is the Diffrence??
Comment
Tutorial Tools
Tutorial Category
DEP - Enable or Disable Tutorials
Burning to CD and DVD - Enable or Disable Tutorials
Enable/disable iPV6 Network & Sharing
Windows Experience Index - Enable or Disable Tutorials
UAC: Is there a GPO option to disable/enable UAC? Vista security
