| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Index - Enable or Disable |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Index - Enable or Disable Hi bmp, You will not get any errors by disabling the Index. Disabling the Windows Search service (Option One) will disable the Index completely, while Option Two will just disable it for the drive you selected. Hope this helps, Shawn |
| Vista Ultimate | Re: Index - Enable or Disable Thanks for reply.So now if i Disable Windows Search service option one it will disable Index completely thn i dont need to Disable like Option two way...... So if for scurity or safety reason i ask again it will safe to do this( I wants to disable from Service) and after disable it i can search for file anyway right???(I know search will be slow)and after disable it perfomance will be littlebit better(Maybe) right? Sorry for asking help but very newbie ....thts why.... |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Index - Enable or Disable No problem bmp. Yes, it is safe and not a security risk. You will still be able to a normal slower non-indexed search with accurate search results. With the Index disable it can help stop your hard drive from running as much in the background. |
| Vista Ultimate | Re: Index - Enable or Disable Thanks Brink for great support ..really helpfull. P.s I disabled windows Search from services without any prpblem.But i didnt Unchecked it from My computer C drive: Index this drive for faster searching or i need to Uncheck this anyway.... |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Index - Enable or Disable bmp, with the Service disabled there is no need to uncheck it from My Computer to. Disabling the Service disables the Index completely. |
| HOME PREMIUM SP1 32bit | Re: Index - Enable or Disable luvin it -- thank you!! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Index - Enable or Disable Your welcome VMLENZA. Shawn |
| vista | Re: Index - Enable or Disable What is the downside to have this indexing disabled. A slower search or incomplete search? |
| Vista BE x64 | Re: Indexing Service (Search) I did manage to get Google Deskop to install on 64-bit Vista and that was to use the /FORCE switch. Apparently this is what XP 64-bit users need to do.Google does warn that by forcing the install that the app may or may not work properly - thus far I've experienced no ill side effects |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Index - Enable or Disable The downside is that the search will take a bit longer to do since it is searching everything instead of just the indexed files. However, your search results will be accurate now instead of waiting on the index to finish updating itself for accurate results. Hope this helps, Shawn |
| Tutorial Tools | |
| Tutorial | Category | |||
| DEP - Enable or Disable | Tutorials | |||
| Burning to CD and DVD - Enable or Disable | Tutorials | |||
| Enable/disable iPV6 | Network & Sharing | |||
| Windows Experience Index - Enable or Disable | Tutorials | |||
| UAC: Is there a GPO option to disable/enable UAC? | Vista security | |||
