Vista - Default Programs
Comment
Old 06-11-2007
Brink
Default Programs
How to Associate a File Extension Type With a Program in Vista
Old 01-09-2009
Brink
Re: Default Programs
Peter,
The problem is that you do not want .dat files to be associated to be opened by only on default program. Since these are data files, doing so may cause a program to no longer work since that specific program will no longer be able to open it's .dat files for it.
Old 01-12-2009
P0P0V83
Vista Home Premium 32bit
Quote  Quote: Originally Posted by Brink View Post
Yes I want that, but my computer doesn't want
ok so you think I have a prog that is in priority with .dat files and that's why I can't clic the "always" box ?
Old 01-12-2009
Brink
Peter,
Peter,
Vista will not let .dat files be associated to just one program as per the stated reason above.
You can only manually "Open With" a single .dat file at a time with a program you want instead.
Old 01-13-2009
P0P0V83
Ok, but I can with my other computer and vista ...
sometimes there are curious things with computers
Thanks you Brink for your help, explanations and time
Peter
Old 01-13-2009
Brink
That is curious indeed.
You might try System Restore, or a repair (upgrade) install to attempt to fix this.
Old 03-01-2009
nhnt11
Vista Home Premium x86 SP1
Hey, my DLL files have been associated with Windows explorer by mistake, and if i double click them by mistake, it keeps opening multiple explorer processes non-stop til i shut down. DLL files arent listed in default programs, so i dont know how to reset it. please help!!!
thanks in advance
Old 03-01-2009
Brink
Hello Nhnt11, and welcome to Vista Forums.
The .dll file extension should have nothing associated it to. You can use the tutorial below to unassociate the .dll file extension so that is not associated to anything again.
Unassociate File Extention Type
Old 03-02-2009
nhnt11
Thanks a lot! Worked like a charm
Old 03-02-2009
Brink
You're welcome Nhnt11.
Old 03-02-2009
nhnt11
hi again, I just realized that DLL files now have the default icon (the blank page). Aren't they supposed to have a kind of page with gears on it? How do I get the icon back? I tried resetting the icon cache, but it didnt help...
Comment
Tutorial Tools
Tutorial Category
Default Programs - Program Default Associations Tutorials
Re: vista ultimate 64-bit default programs and IE7 default email p Vista mail
Involuntary Program Default - ALL Programs have same default to op Vista installation & setup
Adding new programs to Default Programs list Vista General
What are the default Vista programs in "Media Center Programs"? Vista file management
