Vista - System Restore Point - Shortcut
Comment
Old 06-23-2007
Brink
How to Make a Create System Restore Point Shortcut in Vista
Old 01-31-2008
go-to-lady
Vista Home Premium 32-bit
Thumbs up Re: System Restore Point - Shortcut
Quote  Quote: Originally Posted by Brink View Post
LOL ! Yeah, when you need to create System Restore Points all the time, it can be a pain and time consuming to go through all the steps each time.
Have a great day,
Why climb the stairs when the express elevator takes you right there! (Former New Yorker!)
System Restore Points are life savers. I create them before every single change, no matter what it is.
Of course I created one right after installing my new, currently most favorite shortcut!
Steph
Old 02-01-2008
beauparc
Home premium 32
Thanks Brink. Working perfectly now
Old 02-01-2008
Brink
Your welcome beauparc. I'm glad to hear that it is working for you now.
Thank you for the feedback.
Old 04-24-2008
djt0707
Vista Ultimate 32bit
Does anyone else get an error if they cancel the restore point operation?
Old 04-27-2008
Brink
Hi Djt0707,
You can click OK to clear the error and cancel the restore point creation. It is a part of the shortcut that I do not know how to prevent.
NOTE: If you close or click Cancel instead, you will get a error message. Just click OK after the error and it will close without creating a restore point.
Old 05-31-2008
Brink
Updated to have the shortcut work even better.
Old 06-08-2008
TheShadow
XP-Pro-SP3-32bit, Vista Ultimate-64bit
Cool Re: System Restore Point - Shortcut
Hello to the group!
I was referred to this forum by the owner of another technical forum.
So far, so good.
I just have one problem with the "Create Restore Point" script as given earlier in the forum.
To be ultimately useful, the script should be able to run from a batch file or Startup folder without operator intervention.
In XP, I set such an automatically running script in my customers "Startup" folder, to that they get a new restore point every day when they first start up their PC.
Heck, I even set it up that way on my own PC.
I've seen way too many PC's with NO restore points being made for weeks on end.
Then something happens when I need to take the PC back maybe just a few hours or a day or two....and #%$@#&, there's NO restore point to go back to.
Having the script run automatically from the Startup folder takes care of that little problem. There's always a fresh Restore Point when I need one.
I test so many pieces of software every week, that I rely heavily on my restore points to "Back UP" when something doesn't work properly.
The script as presented in this thread is a great little script, but, it forces operator intervention. Not good!
I've found that the one I used for XP, works just fine for Vista as well.
The writer was somewhat of a jokester and every point is labeled "Hacked The Registry".
Well, it does stand out among the other restore points, so I just left it that way.
I'd gladly post the text of the script here.....but I'm not sure that would be appropriate.
Thanks guys, for a great site!
The Shadow
Old 06-08-2008
Brink
Hi The Shadow,
You can post the script if you would like to. An alternative is always welcomed.
Since System Restore creates a restore point of it's own once a day on a schedule, which can be changed in Task Scheduler, I posted this one so people could easily create a restore point manually as needed. That's all.
I'm glad that you like the site.
Old 06-08-2008
TheShadow
Hi The Shadow,
Thanks Shawn,
Well you know us "Old Timers",,,, we're kind of creatures of habit and sometimes march to a different drummer.
If just one Beer will kill your thirst, Two Beers will make you feel good.
I guess I just don't trust the Task Scheduler to give me the Restore Point I need, when I need it. And the task scheduler will give me just one Restore Point a day, even though I may restart my PC six times a day and test six different programs, that can screw up my PC.
Also, I'm not your average bear.....I run my computer a bit differently than most.
I actually back it (C: ) up with Ghost 2003 at least once a week, and sometimes twice or more, depending on what I'm doing.
From my DOS boot floppy disk, CD or Flash Drive, I can run NTFS4DOS and then run several batch files that delete my Pagefile, old restore points and all temp files and other garbage files, before I actually run Ghost.
On my PC, that eliminates about 3 gigs of pure crap from ever going into my Ghost Backup Image File.
So, all those extra Restore Points that I'm making get the axe during the Backup process.
You don't need restore points when you've got an entire backup of C: , "In the Can".
Anyway, since you said it's OK, here's my script to force a Restore Point.
Set SRP=GetObject("winmgmts:\\.\root\default:Systemrestore")
CSRP=SRP.CreateRestorePoint("Hacked the registry", 0, 100)
I thought the "Hacked the registry" comment, from the writer of the script, was kind of cute, so I just left it in. ( No, I'm not the original author! )
That comment inside of quotes and in Blue, can be edited to what ever you like.
Besides, putting this script in my root directory and a shortcut to it in my "Startup" folder, I made another shortcut to it and put that in my 'Quick Launch Toolbar' so I can make a "Quickie" Restore Point whenever I want to with just one click of my mouse. NO Operator Intervention Required!
It's a bit shorter than the other script. And even though written for Windows XP, it appears to run OK on Vizduh. Most systems, anyways.
Thanks again guys!
The Shadow
Old 06-08-2008
Brink
Thank you The Shadow for posting the script. I'm sure people will find it useful.
LOL, I make so many backups it's not even funny with all of the experimenting I do.
Comment
Tutorial Tools
Tutorial Category
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore Not Saving Restore Point Vista General
System restore hasn't held a restore point since I installed Vista Vista General
Deleting System Restore Point Vista General
