Recycle Bin confirmation
How to Enable or Disable the Recycle Bin Delete Confirmation Dialog in Vista
This will show you how to enable or disable the delete confirmation dialog box for the Recycle Bin when you delete something. It is enabled by default.
You can press and hold Shift key, right click on the file or folder you wanted to delete, click on Delete, and release Shift to permanently delete items.
EXAMPLE: Recycle Bin Delete Confirmation Dialog Box
1. Right click on the Recycle Bin desktop icon.
2. Click on Properties.​
3. To Enable
A) Check the Display delete confirmation dialog box. (See screenshot below step 5)​
B) Go to step 6.​
4. To Disable
A) Uncheck the Display delete confirmation dialog box. (See screenshot below step 5)​
5. Click on OK. (See screenshot below)​
Your welcome Guy.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
