Taskbar Toolbars
How to Add or Remove a Toolbar on the Taskbar in Vista and Windows 7
A toolbar is a row, column, or block of buttons or icons representing tasks you can do within a program or files in a folder. This will allow you to add Quick Launch, any folder shortcuts, internet links, address bar, or a desktop shortcuts to the taskbar as a toolbar for quick access.
1. Right click on the Taskbar. (See screenshot below step 3)​
2. Click on Toolbars.​
3. To Add a Toolbar
A) Click on the listed menu item to the right, that you want for a toolbar on the taskbar, to check it.​
NOTE: See the Listed Menu Items section below to see what each option will give you for a toolbar.​
LISTED MENU ITEMS:
  • Address: A navigational address bar like in Explorer and IE7.
  • Windows Media Player: Enable this, and when you minimize WMP you will have a mini player on the Taskbar.
  • Links: Adds a folder shortcut for Links in your Internet Explorer Favorites Bar. You can add whatever internet favorites you like to Links. Click on the arrow (boxed in red below) to see the expanded contents.
  • Desktop: Adds a shortcut for all of your desktop items whether you have your defualt items checked to be seen or not. Click on the arrow (boxed in red below) to see the expanded contents.
  • Quick Launch: Adds the Quick Launch feature for quick access to programs. For Windows 7, see this tutorial instead.
  • New Toolbar: Similar to Links and Desktop above, but allows you to add any folder of your choice to the taskbar as a toolbar.
    NOTE: This does not move the folder's location. It only copys it as a shortcut for the toolbar.
    • If you click on it from step 3 above, you will have a browse window open. (See screenshot below)
    • Navigate to the folder you want and highlight it and click Select Folder button. (EX: Downloads)
    • Click on the arrow to see the expanded contents of the folder.
4. To Remove a Toolbar
A) Right click on the Taskbar. (See screenshots below)​
B) Click on Toolbars.​
C) Click on the added toolbar from step 3 to uncheck it.​
Shawn,
Windows Media Player: Enable this and then open Windows Media Player 11, minimise it, and you'll find a mini-player on your taskbar.
Adam,
Thank you for the information. The post has been updated to include it.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hello Mizaras, and welcome to Vista Forums.
Yes. This is the free program RocketDock. You can download it from here:
RocketDock - Download RocketDock
It says that 64 bit is not supported, but I use it on my 64 bit Vista without any problems.
Have fun,
