Vista Tutorial - System Restore - disk space
Comment
Old 05-30-2007
Brink
Administrator
How to Change the System Restore Disk Space Usage Amount in Vista
Old 04-06-2008
DjLevel9
Banned
Vista 32 Ultimate SP1
Re: System Restore - disk space
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>vssadmin list shadowstorage
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2005 Microsoft Corp.
Shadow Copy Storage association
For volume: (C\\?\Volume{9707de3c-9d94-11dc-bb54-806e6f6e6963}\
Shadow Copy Storage volume: (C\\?\Volume{9707de3c-9d94-11dc-bb54-806e6f6e69
63}\
Used Shadow Copy Storage space: 65.193 GB
Allocated Shadow Copy Storage space: 67.45 GB
Maximum Shadow Copy Storage space: 68.427 GB
C:\Windows\system32>vssadmin Resize ShadowStorage /For=C: /On=C: /Maxsize=3GB
Successfully resized the shadow copy storage association
Old 04-06-2008
Brink
Administrator
Hi DjLevel9,
That is a lot of space for restore points, but Vista uses 15% of your hard drive space by default. I would say only if you need to save space, or want to increase it to be able to store more restore point dates.
Old 04-06-2008
DjLevel9
Banned
Used Shadow Copy Storage space: 0 GB
Allocated Shadow Copy Storage space: 0 GB
Maximum Shadow Copy Storage space: 3 GB
Old 04-06-2008
Brink
Administrator
That will save you space alright.
Old 04-06-2008
DEANREILY
Vista Home Premium 32 Bit
Be careful not to over do the shrinking of the restore point memory. Each time Vista or an application is updated a new restore point is generated and old ones may be eliminated if there is not sufficient storage.
In one case this resulted in my no longer having a restore point that I needed. It would be nice to be able to protect a restore point from being eliminated as a result of an undetermined string of automatic update processes. Do you have any instructions on how to do that without increasing restore point memory significantly.
Old 04-06-2008
Brink
Administrator
Sorry DeanReily,
It is not possible to save just any one particular restore point or prevent the oldest one from getting deleted when you run out of hard drive space. The only way to help is to increase the amount of space used for restore points on the hard drive, but even then you will run out of space eventually. The best option is to use a good backup program.
Sorry,
Old 06-16-2008
nigel2205
Vista Home Premium 32bit
Hi
trying to reduce shadow storage, keep getting error msg
For volume: (D\\?\Volume{3ddf0d5c-3a52-11dd-b79b-0019db2d605e}\
Shadow Copy Storage volume: (D\\?\Volume{3ddf0d5c-3a52-11dd-b79b-0019db2d60
5e}\
Used Shadow Copy Storage space: 1.703 MB
Allocated Shadow Copy Storage space: 100 MB
Maximum Shadow Copy Storage space: 33.911 GB
For volume: (C\\?\Volume{ea3d4cb6-3a4e-11dd-91c8-806e6f6e6963}\
Shadow Copy Storage volume: (C\\?\Volume{ea3d4cb6-3a4e-11dd-91c8-806e6f6e69
63}\
Used Shadow Copy Storage space: 4.941 GB
Allocated Shadow Copy Storage space: 5.792 GB
Maximum Shadow Copy Storage space: 17.977 GB
C:\Windows\system32>vassadmin Resize ShadowStorage /For=C:/On=C:/Maxsize=5GB
'vassadmin' is not recognized as an internal or external command,
operable program or batch file.
C:\Windows\system32>vassadmin Resize ShadowStorage /For=C: /On=C: /Maxsize=5GB
Old 06-16-2008
Brink
Administrator
Hi Nigel,
Welcome to Vista Forums.
Check to make sure that you did the Run as administrator in step 3.
Plus, you should type:
vssadmin Resize ShadowStorage /For=C: /On=C: /Maxsize=5GB
instead of:
Notice the spaces that were left out after C: also.
Old 06-16-2008
nigel2205
Thanks Shawn
Copy & paste worked great,
Best forum iv found for Vista.
Old 06-16-2008
Brink
Administrator
Your welcome Nigel. Glad it worked for you now.
Comment
Tutorial Tools
Tutorial Category
Solved Managing System Restore Disk Space Usage General Discussion
Local Disk/System Restore/"eating" up space General Discussion
disk space Vs restore points Vista performance & maintenance
How To: Reduce Disk Space Used By Windows Vista System Restore Vista General
System Restore increase disk space used Vista General
