Shutdown Vista from the Keyboard
How to Shutdown Vista from the Keyboard
This is to Shutdown, Restart, Switch User, Log Off, Sleep, or Lock Vista from the keyboard or mouse. This can be helpful if your mouse has stopped working or you just want to use a quick keyboard shortcut.
You can Lock the computer by pressing the Windows Key + L keys.
OPTION ONE
Through the Start Menu
NOTE: This is for the shutdown options for Vista.
1. Click on the Start Logo.gif button or press the Windows key.​
2. Click on the arrow button or use your arrow keys to move over to the shutdown options. (See screenshot below)​
3. Click on a shutdown option or press Enter to run the selected option.​
OPTION TWO
Through the Alt + F4 Keyboard Shortcut
NOTE: This will also close any active open window when pressed. If you no longer have a working mouse or would prefer to use the keyboard, then press Alt + F4 until you get to the desktop.
1. Minimize or close any active open window(s) and go to the Desktop.​
2. Press Alt + F4.​
3. Click on the drop down arrow to select the option you want or use the Tab key and the Up and Down arrow keys to. (See screenshots below)​
4. Click on OK or press Enter to run the selected option.​
NOTE: The shutdown option this window opens with by default can be changed to either Shutdown or Sleep. For how, see: How to Change Power Button settings for the Start Menu and Case in Vista
If you see the screenshot below instead when you press Alt + F4, then see:
do you know what a shortcut would be that would allow yu to prompt the Alt+F4 shutdown menu?
so that you could assign it to a shortcut on the desktop or something and then choose what you want to do?
Hi Dukeblue17,
Welcome to the forum. :party:
None that I am aware of for the complete ALT+F4 Shutdown Menu. You could download the individual shutdown options, from the related links above, and add them to Quick Launch. This way you can just have a one click shutdown option then.
If you need help with Quick Launch, see: How to Use Quick Launch in Vista
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
