Vista - Speed Up the Performance of Vista
Comment
Old 07-29-2007
Brink
How to Speed Up the Performance of Vista
Old 02-25-2008
Vista Home Premium 32bit
Re: Speed Up the Performance of Vista
Hi Brink, wow I can't wait to get started. This may be a silly question, but how do I know what kind of mother board I have so I can update the Bios? I have an HP Pavillon with an AMD 64x2 dual core processor 4800 + 2.5ghz. 1918mb ram. Oh, and 32 bit op system.
Thanks, Case
Old 02-25-2008
Brink
Hi Case,
Do you know the model number of the HP Pavillion?
Old 02-25-2008
Hey Shawn, yes it is m8013w. Also, do you know of a good place to buy ram memory.
Much appreciated,
Old 02-25-2008
Brink
Case,
You can download the BIOS from here:
Software & Driver downloads*HP Pavilion Media Center TV m8013w Desktop PC
If you need specs on your system, then see:
HP and Compaq Desktop PCs*-* Motherboard Specifications, M2N68-LA (Narra)*
Any reputable retail place (Online or Store) is great place to buy RAM. I would just go with who has the best price for the RAM you need. Online may be a bit cheaper, but a store is easier and faster to deal with if you have problems with the RAM.
Old 02-25-2008
Thanks a lot Shawn. I really appreciate the help. This is a cool site.
Old 02-25-2008
Brink
Your welcome Case. I'm glad that you like the site.
Old 02-26-2008
Shawn, another question if you don't mind. When I turned off remote differential compression, I noticed in your example, you have Windows DFS Replication service turned off. Mine is checked. Should I uncheck it? Also, on step 16 do I have to enable 'yes' on Require a password on wakeup. Mine is set to 'no'.
Thanks,
Casey
Old 02-26-2008
Brink
Hi Case,
If you do not need DFS Replication, and most people do not, then it will be fine to uncheck. You can read more on it here to determine if you do need it or not.
Windows Vista SP1 Services Information - DFS Replication
If you want it set to where you have to enter a password when the computer wakes up from sleep or hibernation, then yes you will need to select Yes.
Old 02-28-2008
Thanks again Shawn
Old 02-28-2008
Brink
Your welcome Case.
Comment
Tutorial Tools
Tutorial Category
How to test USB speed / performance Vista hardware & devices
Oblivion and Vista Speed/Performance :: Help Needed Vista Games
speed and performance information Vista performance & maintenance
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
ReadyBoost, Speed up your PC’s performance Vista General
