Disk Defragmenter from Command Prompt
How to Run Disk Defragmenter from the Command Prompt in Vista
This will show you how to run Vista Disk Defragmenter from the command prompt instead of the program within Vista to use more options and details.
Wait until your hard drive stops running before closing the command prompt to allow the defragmentation to finish. It may take a while to finish depending on how large and fragmented your hard drive is.
2. Choose the option you want to do below.​
3. For a Complete List of Commands -
A) In the elevated command prompt, type defrag.exe -? and press Enter. (See screenshot below)​
4. To Defragment a Drive or Volume -
A) In the elevated command prompt, type a option in bold below you want to do. (See screenshot below)​
  • defrag.exe c: for the C: drive
    NOTE: You can use whatever drive letter to defrag it.
  • defrag.exe -c for all drives or volumes.
B) Press Enter.​
5. To Perform an Analysis Only and Not Defragment -
A) In the elevated command prompt, type the option in bold below. (See screenshot below)​
  • defrag.exe c: -a for an analysis on the C: drive
B) Press Enter.​
6. To Perform a Partial Defragmentation Only -
  • defrag.exe c: -r for the C: drive.
  • defrag.exe -c -r for all drives or volumes.
B) Press Enter.​
7. To Perform a Full Defragmentation -
  • defrag.exe c: -w for the C: drive.
  • defrag.exe -c -w for all drives and volumes.
B) Press Enter.​
8. To Force a Defragmentation on a Drive With Low Space -
A) In the elevated command prompt, type a option in bold below you want to do. (See above sections)​
  • defrag.exe c: -f for the C: drive.
  • defrag.exe c: -w -f for the C: drive with full defragmentation.
  • defrag.exe c: -r -f for the C: drive with partial defragmentation.
  • defrag.exe -c -f for all drives and volumes.
  • defrag.exe -c -w -f for all drives with full defragmentation.
  • defrag.exe -c- r -f for all drives with partial defragmentation.
B) Press Enter.​
9. For Verbose or Detailed Mode -
  • defrag.exe c: -f -v for the C: drive.
  • defrag.exe c: -a -v for the C: drive with analysis.
  • defrag.exe c: -w -f -v for the C: drive with full defragmentation.
  • defrag.exe c: -r -f -v for the C: drive with partial defragmentation.
  • defrag.exe -c -f -v for all drives and volumes.
  • defrag.exe -c -w -f -v for all drives with full defragmentation.
  • defrag.exe -c- r -f -v for all drives with partial defragmentation.
B) Press Enter.​
Re: How To Make Vista more responsive and faster
Brink, just a note... it seems like the -b switch to defrag boot files still works, even though when you do "defrag /?" it doesn't show up in the param list. I just defragged with -b switch.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Strange MilesAhed, I cannot get defrag.exe -b to work in a elevated command prompt, but can with this tutorial's shortcut.
http://www.vistax64.com/tutorials/157357-defragment-boot-files-create-shortcut.html
Hmmmm, do Path and see if C:\Windows\system32 is in your path
I have Auslogics defrag but their command line version is cdefrag.exe. I don't see another defrag.exe on my machine. Plus doing defrag /? brings up the help info so it must be going to the windows defrag.exe
That's weird. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Tru Dat. ;)
is there a command thats possbile to disable everything related to defrag so it doesnt run auto like when i turn on my computer the defragger always says "Analyzing disk" and it lags up my hole computer and i turned off te schedual thing already
    M8430F
    Q6600
    IPIBL-LB (Benicia)
    4gb
    Evga 250 GTS
    24" Samsung T240HD
    750gb
    OCZ GameXStream 700-Watt
    NZXT Tempest ATX Mid-Tower Case
    Air
    Logitech G19
    Logitech G500
    Bell Max 10
Hi Bobo,
Is this happening during boot, or when Vista starts up?
Since you already turned off the Disk Defragmenter schedule, you might check to see if it is listed as a startup program.
If this is happening during boot up, then see if letting it finish will stop it from running at the next boot up.
Hope this helps for now,
Hello David,
When it's done, you will see the C:\Windows\System32> command prompt at the bottom. It depends on how large your hard drive is and how defragmented it is for how long it may take to run though. I would plan for it to run for around a hour to be safe though.
You're welcome David. I find that the free program Auslogics Disk Defrag is a great one to use in Vista.
I am having issues involving trying to defrag.My hard drive is 297 G. Each time I defrag my C drive properties says I have less and less free space and then reccommends to defrag.I have defraged both through normal methods and command prompt using advice from this forum. I've scanned my systems and it reports no file errors or bad clusters. I use this computer daily and don't have a back up laptop to use while trying to send this one to be looked at by someone more knowledgeable. I have already done a full backup of all files and programs, and am thinking to reset computer to factory specs. I don't understand.Please advise.Thank You
I have tried your methods of system defragmentation but what happens is that a command box flashes up for second then disappears. I've tried various commands suggested in the tutorial but none of them work. Please help :(
Hello Kittsville, and welcome to Vista Forums.
See if running a sfc /scannow command may be able to fix the command prompt for you so that it will stay open afterwards.
You can also use Disk Defragmenter instead to defrag.
Brilliant! I never knew about this before. Just done it on my laptop which has never been done before. Took ages, but, I had 51.2GB free space before, now I have 83.3GB free! Thanks :)
    HP G60 Notebook
Brink, you are amazing. I was getting nowhere at all with the GUI, but this got right to work. This machine is going out the door so I didn't want to install Defraggler.
Be well,
p.
    dell precision
    2G ddr2
    matrox
You're most welcome. :)
Hiyya Shawn I am running this one too as the Auslogics came up with me having to buy a fix it program and I was under the impression that it was a freebie.
Trouble is there are so many defrag apps now it makes your head spin:confused:
Anyway it seems logical to me to run the Windows one anyway.
John
    LEC
    E4500 duo core
    D945GN
    2GB
    Inbuilt
    Inbuilt
    LCD
