Boot Partition - Default
How to Change the Default Boot Partition Settings in Vista
This will show you how to select or change which operating system (OS) you would like to load as the default at startup when you dual boot with multiple operating systems. You will also see how to turn on or off and adjust how much time to display the operating system selection during boot up.
EXAMPLE: Windows Boot Manager
METHOD ONE
Through Startup and Recovery Options
1. Open the Control Panel (Classic View).​
A) Click on the System icon.​
B) Go to step 3.​
OR
2. Open the Start Menu.​
A) Right Click on Computer and click Properties.​
3. Click on the Click to Play button in the video below.​
4. To Change the Default Operating System to Start Up -
A) Click on the OS to highlight it. (See frame 5 in video)​
B) Click on the Set as default button.​
5. To Change the Amount of Time to Display the List of Operating Systems at Boot -
NOTE: Also known as the Windows Boot Manager.
A) Uncheck the Time to Display the List of Operating Systems at Boot box to turn off the display list at boot up. (See frame 4 in video)​
B) Uncheck and Check the Time to Display the List of Operating Systems at Boot box to reset to the default time of 30 seconds.​
C) Check the Time to Display the List of Operating Systems at Boot box to adjust the time you want to display the list.​
NOTE: Typing 0 (number) will effectively remove the OS choice at boot. The default time is 30.
6. To Change the Amount of Time to Display the Recovery Options When Needed -
A) Uncheck the Time to Display the Recovery Options When Needed box to turn off the display of options at boot up. (See frame 4 in video)​
B) Uncheck and Check the Time to Display the Recovery Options When Needed box to reset to the default time of 30 seconds.​
C) Check the Time to Display the Recovery Options When Needed box to adjust the time you want to display options.​
7. Click on OK. (See frame 6 in video)​
8. Click on OK. (See frame 7 in video)​
METHOD TWO
Through System Configuration
1. Open the Start Menu.​
2. In the white line (Start Search) area, type msconfig and press Enter.​
3. If prompted, click on Continue in the UAC prompt.​
4. Click on the Boot tab. (See screenshot below)​
5. To Change the Default Operating System to Boot to -
A) Click on the OS to highlight it. (See screenshot above)​
C) Go to step 8.​
6. To Change the Amount of Time to Display the List of Operating Systems at Boot -
A) In the Timeout field, enter a number between 3 and 999 seconds you want to have to make a OS choice at boot up. (See screenshot below step 4)​
B) Check the Make all boot settings permanent box. (See screenshot below step 4)​
C) Click on Yes to confirm.​
D) Click on the Restart button. (See screenshot below)​
NOTE: If you do not see this box, then you have checked the Don't show this message again box at some earlier time before. Be sure to restart the computer to apply the changes anyway. To restore this Restart box, see: How to Restore the System Configuration Restart Prompt in Vista
WARNING: This will restart the computer immediately. Make sure you save and close anything open you do not want to lose.​
E) If the OS selection wait time is to short or long, then just repeat these steps and make the time changes.​
7. To Delete a Operating System from the Boot List -
NOTE: Vista will not let you delete the OS that is set as the Current OS; Default OS. You will need to change it to another OS listed first in step 5.​
A) Click on the OS you want to remove from the boot list to highlight it. (See screenshot below step 4)​
B) Click on the Delete button.​
8. Click on OK. (See screenshot below step 4)​
Did you click Play when the video loaded?
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Hi toml 12953,
You would click on Classic View in the upper left corner of the Control Panel to see the icons instead of links.
There are 8 frames in the video. Be sure to click on Click to Play on the video after it loads. You may need to reclick it if it did not play properly.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hello!
I have two questions:
1. Can I unchecked the Time to Display the List of Operating Systems at Boot box so it will be 0 second AND do the msconfig method at the same time too? If yes, must they be set at the same amount of seconds and what is the minimum #?
2. Since I was in this msconfig mode, I wandered to the startup option, this is my startup screenshot:
attachment.php
Is there any program in this startup that I can disable to speed up without hindering my comp use?
Thanks.
Hi Bennys,
Your attached image seems to be not working.
Setting this setting in either location will change it in both locations. There is no need to do it in both of them. Setting it to 0 is the same as unchecking it from either location.
Wow great tutorial! Definitely a timesaver. I'd love to know how you made that fantastic video. I've gotten good at reading directions and going through the process, but it usually means referring back to said directions several times. With that video I just watched it twice and was able to carry it out with no snags. Fantastic work!
Hello Pawl, and welcome to Vista Forums.
I'm happy that you found it helpful. The video was created using Demo Builder.
Hi Shawn, what do you have yours set on in "Time to Display the Recovery Options When Needed"?
Thanks, Casey
Hello Casey,
I just left the Time to Display the Recovery Options When Needed set at the default 30 seconds. :)
When I go to MSCONFIG>Boot, the operating system is listed as "Windows Vista (TM) Home Premium (recovered)". How can I change the name to get rid of the (recovered)?
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech K350 Wireless Keyboard
    Logitech M705 Wireless Mouse
AWESOME! Thanks alot!
    AMD
    ASUS M3A78-EM
You're most welcome Andy. :)
