Folder Options
How to Open and Change Folder Options in Vista
Folder Options can change the way files and folders function, as well as how the content in folders are displayed.
STEP ONE
How to Open Folder Options
2. Click on the Folder Options Icon. (See screenshot below)​
OR
1. In a Windows Explorer window.​
2. Click on the Organize button. (See screenshot below)​
3. Click on Folder and Search Options.​
OR
2. Click on the Tools menu. (See screenshot below)​
3. Click on Folder Options.​
STEP TWO
How to Change Folder Options
NOTE: The Apply to Folders button will be grayed out unless you open it from within the same window that you want to apply the same changes to the other windows with the same folder type templates.
1. To Change the Folder Options Advanced Settings
A) Check or Uncheck the options you want or do not want. (See screenshots below step 3)​
NOTE: For more information on these options, see: Windows Help and How-to: Change Folder Views and Behavior
B) Go to step 3.​
2. To Restore the Default Folder Options Advanced Settings
A) Click on the Restore Defaults button. (See screenshots below step 3)​
3. Click on OK to apply the changes and close options.​
Hello Kayla, and welcome to Vista Forums.
You would right click on a empty space on the desktop or in Windows Explorer (main pane) and click on New and Folder. You can see an example of this at: http://www.vistax64.com/tutorials/69837-new-folder.html
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
