Logon with Username and Password
How to Make Vista Require a User Name and Password at Logon
This will change the logon procedure in Vista to require all users to type in their user name and password instead of selecting their user icon and typing in just their password to logon their user account. This is like the old classic Windows logon screen.
For the user name, you would type your account's User name, or to logon to a domain, you would type Domain Name (Computer Name)/User name instead. If you have no password, then just leave the field empty. You can press TAB or SHIFT+TAB to move between the User name and Password fields if you entered something incorrectly. See the example screenshot below.
EXAMPLE: User Name and Password Logon Screen
NOTE:
See the NOTE box at the top of the tutorial. However, with this option the user display picture will be blank, since there is no actual user icon now.
OPTION ONE
Using a REG File Download
1. To Enable User Name and Password Logon
Enable_Username&Password_Logon.reg
download
B) Go to step 3.​
2. To Restore the Default Logon
Restore_Default_Logon.reg
download
4. Right click on the download .reg file and click on Merge.​
NOTE: The next time you go to a log on screen, you will be required to enter your user name and password to logon to Vista in your user account.
7. You may also wish to set the same setting for the locked computer screen: How to Display User Information or Not when a Windows Session is Locked
OPTION TWO
Manually in Registry Editor
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
5. In the right pane, right click on dontdisplaylastusername and click on Modify.​
6. To Enable User Name and Password Logon
A) Type 1 and click on OK. (See screenshot below step 7)​
B) Go to step 8.​
7. To Restore the Default Logon
A) Type 0 (number zero) and click on OK.​
8. Close regedit.​
NOTE: The next time you go to a logon screen, you will be required to enter your user name and password to logon to Vista for your user account.
9. You may also wish to set the same setting for the locked computer screen: How to Display User Information or Not when a Windows Session is Locked
  • Enable_Username&Password_Logon.reg
  • Restore_Default_Logon.reg
i tried this and it errored out when i clicked okay. i did this from a user account that is not the admin. Any suggestions? i need this TO get Vista to prompt for the username so i can type in the correct username for the admin account.
Hi Mikhayah,
Yes, this is normal. You will need to do this tutorial in a Administrator account or provide the Administrator password when prompted by UAC.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Man, that's really rough. It's hard to believe that MS never thought that someone might put in a wrong Username and need to type it in correct; as there is no way to type in a correct password for a wrong Username. That's really a HUGE flaw of Vista. People type things in wrong and need to be able to change it without reinstalling the entire OS.
LOL Mikhayah,
I thought you were talking about doing the tutorial. LOL :o
You can press Tab or Shift+Tab to go back to Username to re-enter it.
Nah, the tutorial seems fine, but it's just not working in my case.
Also, i just tried tab and tab-shift and it just moved around to everything (as tab does), but didn't open a field for Username.
Mikhayah,
Strange. After I entered a wrong username and password on purpose, I got the error like you. I clicked OK, then was able to press Tab to move back and forth between the Username and Password field.
Mikhayah,
I would just go back to the default of just typing in the password for the user account.
Is it not showing your Administrator account display picture asking for the password using the default logon?
Yeah, it's super weird man... i type in the password and it says it's denied and that it is "either" a wrong password "or" a wrong username...
Well the thing is that under users, there is the ORIGINAL name and not the saved one, AND the password hint is the original password hint.
The image is the image that was used for the original username. Only the typed in name for the username is different... a name my wife was trying to change it to, but it said it didn't happen (and again, under users it is not listed). i just can't get it to prompt me for a different username.
Mikhayah,
It sounds like something got corrupted somewhere. You may end up having to do a reinstall. Try to see if you can gain access by resetting the password. If nothing else, you may be able to create a new Administrator account in Safe Mode to use and delete the others after you transfer anything you want to keep.
http://www.vistax64.com/tutorials/102005-reset-user-account-password.html
Username+password and one visible account?
Can you make the logon screen have one "other user" account where you have to put the username and password like you described in this article but also have one visible account right next to it? (can you also title that logon box that makes you require the name+password "Other User"
Hi The Guardians,
Sorry, but no. You can only have it set like in this tutorial or like it was by default with all use account icons displayed at logon.
Sorry, :(
Oh, because I thought I saw something like this on a school computer where there was a visible account called "Student" and another called "other user" where you have to put your username and password.
I'm not sure The Guardians. If it was that way, they may have been using some 3rd party program that would allow that.
I've been looking for this for weeks!
Thanks Brink,
Fearghal :D
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
You're welcome Fearghal.
why they reomoved the way to change the log on screen like in xp where you could change from the picture logon to the user name and password using a key combonation. would have been good for this:( (also was good for pc tech fixing pc's on xp:)(good tip from tutor))
jamie
    sont vaio VGN-NR32L
Hello Jamie,
Good question. I wish I had an answer.
now thinking there was a problem with being able to do this in xp was if the administrator accont in xp did not have a password you could get in without going in safe mode without any problems
jamie
    sont vaio VGN-NR32L
