| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Startup Repair |
| Vista Home Premium SP2 32bit / Windows 7 Home Premium 32 bit | Re: Startup Repair Thank you Shawn I'll look into doing it. Just remembered the other disc I got with the machine was for Nero 7 Essentials which would be the cut down version as it say's bundled with hardware only not for resale. Would I still need the ISO recorder program to burn the CD or would Nero do it ? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Startup Repair If Nero has a ISO burning option it will work, otherwise you will need to use the other program. |
| Vista Home Premium SP2 32bit / Windows 7 Home Premium 32 bit | Re: Startup Repair OK thanks I'll look into just what Nero does have, what's listed on the CD is. Nero Express 7 Essentials Nero Show Time 3 Essentials Nero Vision 4 Essentials Nero Recode 2 Essentials InCD 5 Essentials |
| Vista X64 | Re: Startup Repair Hello there, Step 1, 2 and 3 are going well, but i don't have a screen like Step four. Mine pops right into the install screen. So i can't choose for the option: repair your computer |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Startup Repair Hello StaphanO_NL, and welcome to Vista Forums. Did you restart the computer to run the Vista installation DVD from boot and not from within Vista? Shawn |
| Vista X64 | Re: Startup Repair Hello, Yes, i did. Start up the computer, click any key to begin with the installation of the dvd. And then it skips the screen of step four. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Startup Repair Strange. What type of Vista installation DVD do you have? (Ex: Retail, OEM, Express, Recovery ...) You could also create another DVD to be able to use to run a Startup Repair from. This tutorial will show you how to. Create a Recovery Disc |
| Vista X64 | Re: Startup Repair I've slipstreamed a dvd. Maybe the person I've got the image from had already cutted particular things out of the dvd. Is that possible? If so, I will just get a good image and burn that on dvd. Thanks for your quick help so far. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Startup Repair That could very well be. I would get another copy. That Create a Recovery Disc option will let you do the Startup Repair, but it will not let you reinstall Vista if you ever wanted to later though. |
| Vista X64 | Re: Startup Repair I don't want to reïnstall Vista, I just want to repair my damaged vista. So i download a new image and then prepare and burn it with Vlite. I will let you know how that goes. |
| Tutorial Tools | |
| Tutorial | Category | |||
| Vista Startup Repair cannot repair this computer automatically | Vista General | |||
| HELP! Startup Repair | General Discussion | |||
| Startup repair cannot repair this computer automatically | Vista General | |||
| startup repair | Vista General | |||
| Startup Repair | Vista General | |||
