32 Bit Explorer.exe is running by default
nakhan
Hi
I am using Vista Prof X64 Version
My system is running 32 bit explorer.exe by default
What should i change to make it run 64 bit explorer.exe by default
from
nayeem khan
    Intel Quad Core Q9650
    Dell
    8GB
    Intel
    dell
Go to search, type default. In default screen, select explorer as the defaualt browser.
If you ever need 32 bit (possibly with flash) it iwill revert to 32.
Hi
Its not internet explorer its the explorer.exe which is windows explorer
when i first installed the explorer.exe was 64 bit
but now i think vista is running 32 bit version of explorer.exe
how should i find out which explrer.exe vista is running by default
hope you got my question
from
nayeem
    Dell
    8GB
    Intel
    dell
If you installed 64 bit, why do you think that 32 bit is running by default?
Hi
May be some program/virus changed it..... i have removed all the virus/trojans and now its clean ..everything is working fine except the explorer.exe*32
which keeps crashing all the time
system restore is not an option as all available dates have 32 bit explorer.exe settings
any idea how to make vista load 64 bit explorer.exe?
from
nayeem khan
    Dell
    8GB
    Intel
    dell
