Problem With Gadget In Sidebar
SamTheMan
Hi, My Weather Gadget In The Side Bar All Of A Sudden Did This. How Can I Fix It
Thanks
    HP-Pavilion
    Intel(R) Pentium(R) Dual CPU E2220 @ 2.40GHz (2 CPUs), ~2.4G
    3964MB RAM
    NVIDIA GeForce 7100 / NVIDIA nForce 630i
    Speakers (Realtek High Definition Audio)
    Generic PnP Monitor
    1280 x 1024
    488 GB
    USB Root Hub
    USB Root Hub
    Broadband
We are all volunteers and work as quickly as we can. You should not be impatient after 30 minutes.
That being said I will try to help
Try the procedure in the first tutorial
http://www.vistax64.com/tutorials/161046-windows-sidebar-gadget-not-displayed-correctly.html
Then If above does not work run this 3 times if errors are found
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
Works the same in Seven as Vista
If you are removing a gadget per the tutorials above, remove and then boot and then reinstall
The procedure that works for me is to remove, per tut above. Then boot and enable again.
Although the excellent advice from Richard above will most likely resolve the problem with your gadget, here is one alternative recommendation and other weather gadgets to consider in case you might prefer to try something different (and that may resolve the problem simply by installing and using one of them as they are different gadgets).
Do you know when this problem began? Especially if recent, try a System Restore to a point in time BEFORE the problem began. Here's the procedure: http://www.vistax64.com/tutorials/76905-system-restore-how.html. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed and uninstall any software you removed between now and the restore point, but you can use Windows Update for the updates.
Whether or not any of the above resolve the problem, you may simply want to consider a different weather gadget instead of the one you've been using. It may both resolve the problem and possibly offer features the one you're using doesn't have. Here are some options I've found:
Weather Widgets : Weather Underground
Windows Live Gallery
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
try reinstalling the gadget
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Das Keyboard Silent Professional
    Logitech G500
    iunno.
Thanks Guys But Nothing Worked. Also I Tryed To Install NEW Gadgets And Same Thing Happened.
Also Having Problems With The Default Clock
Also Im Not Sure When The Problem Began So I Couldnt System Restore
    HP-Pavilion
    3964MB RAM
    Generic PnP Monitor
    1280 x 1024
    488 GB
    USB Root Hub
    USB Root Hub
    Broadband
Did you close it or unistall it?
Go to the tray with all the gadgets
Click on gadget then uninstall
and my windows help stuff is like that too. What Is Going On!
    HP-Pavilion
    3964MB RAM
    Generic PnP Monitor
    1280 x 1024
    488 GB
    USB Root Hub
    USB Root Hub
    Broadband
What Else Could It Effect. As I Saw In The Warning It Will But Stuff To Default. Like What Other things Might It Change Back?
    HP-Pavilion
    3964MB RAM
    Generic PnP Monitor
    1280 x 1024
    488 GB
    USB Root Hub
    USB Root Hub
    Broadband
Run the SFC command as I posted. It will either fix or give information.
SFC will fix corrupted files.
Edit: Nvm
    HP-Pavilion
    3964MB RAM
    Generic PnP Monitor
    1280 x 1024
    488 GB
    USB Root Hub
    USB Root Hub
    Broadband
If all else fails, try this this. Save it and Double click it, merge.
Restart, see if it's changed.
  • PNG.reg
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless
    Logitech Wireless LX310
    18/2 cable
