DOS shell commands won't work
telluoff
commands like dir and cd work,
commands like ping and sort don't work.
I found an old thread referencing the problem and tried them all.
No luck fixing the problem.
Pathing is correct.
Lost.
    Dell precisiont3400 64 bit
    Intel extreme x950
    8G
    Asus, Dell
What is the exact path variable?
What is the exact error message (if any) that you get?
Thanks for your question.
C:\Windows\System32\cmd.exe
'command' is not recognized as an internal or external command,
operable program or batch file.
    Intel extreme x950
    8G
    Asus, Dell
You didn't answer the question, what is your PATH variable set to. Enter path from the Command Prompt to see.
Also, from the Command prompt, enter
reg query "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options"
See if there is an entry for cmd.exe. If yes, use regedit to delete it.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
Sorry, I was unable to get back to this problem for a while.
I found the solution. I had extension paths in both the system and user variables. This confused the system to the point that it only used the user pathext variable. Once I combined all extension paths in the system variable pathext, it understood the requirements of the cmd.ext.
Thanks for all your help.
    Intel extreme x950
    8G
    Asus, Dell
I found the solution. I had extension paths in both the system and user variables. This confused the system to the point that it only used the user pathext variable. Once I combined all extension paths in the system variable pathext, it understood the requirements of the cmd.ext and everything worked.
    Intel extreme x950
    8G
    Asus, Dell
