fastforward and shaking playback in WMC after changing codec
vitrag24
Hello,
I've HP dv6226tx and using windows vista home premium [updated to sp2]
i was using klite codec pack mega earlier.
i had some problem with selecting one audio in dual audio files, so i wanted to try cccp and shark's codec packs.
i uninstalled klite codec pack and installed cccp.
then if i play movies in windows media center[WMC], it has shacy playback frequently and sometimes fastfrward and freezes sometimes.
so i think, may be problem with cccp, so tried to install shark after uninstalling cccp as i had used them earlier in old pc..
but problem persists.
so i thought, may be klite was perfact ,so rolled back to klite, but still problem persists.
in all these codecs, movie is playing fine in mediaplayerclassic and WMP, but problem with media center playback.
Some info if any relation with problem:
in last week, i had updated my vista from home premium to sp1 and from sp1 to sp2..just added info if it has any relation..
when i uninstalled klite first time, it was showing xvidcore.ddl missing and when i installed it last time, it showed same message and asked to disable it.
Rightnow i've uninstalled klite again and with shark's codec as i hope he'll solve my problem.
Thanks.
I would go to Shark's forum and get advice directly from the programmer. He's on the Win forums too, but he'll be sure to see your question on his forum. There's so many settings I try not to change them if they are working.. so I don't know how to advise you.
http://shark007.net/forum/
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Forum Home
Already posted on his forum and he's trying to help, but posted here too in hope of earlier solution.
I gotcha'. I keep buying these HP media center PCs but I've never tried the TV tuner or media center software. Just got the machines due to general specs/price. I don't have any experience with it. Maybe another forum denizen will pop in and help out.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
