Solved Gigabyte MB + Vista 64-bit + Soundblaster Issues FIXED!
Did This Information Help You?
  • No, I'm still having sound issues :(
    Votes: 0 0.0%
  • Total voters
    4
Syric
Greetings Everyone,
I had a major issue w/ my sound, and finally just figured out what was causing the problem. I wanted to share this following information with any of you that might find themselves losing sleep, dumbfounded, and/or otherwise unable to find help elsewhere (I couldn't find anything on this particular issue!).
The issue: sound distortion, crackling, poping, and other abnormalities w/ sound.
Let's break this down fast:
My System:
- Windows Vista Premium Home Edition 64-bit (6.0, Build 6001) Service Pack 1
- EVGA GeForce GTX 260 Over-Clocked Edition Graphics Card (Drivers: 7.15.0011.8250)
- 640GB Westren Digital Hard Drive
- Intel Core i7 CPU 940Mhz
- Gigabyte EX58-UD4P (Bios version: 6.00PG) MotherBoard
- SoundBlaster X-Fi Xtreme Audio PCI Edition (Driver version: 5.12.0001.2007)
Background Info:
I had a clean installation of Windows Vista (3rd installation after testing w/ another hard drive, and confirming my hardware wasn't causing my sound issues), all Microsoft's recommended/critical updates installed, all Motherboard drivers installed, and so forth. Clean sparkling new system, sound was working great, and then as I was installing other programs .....the sound problem/issue returned (see above for details)
The Resolution:
If you own a GIGABYTE MotherBoard (newer!), and have installed GIGABYTE's Dynamic Energy Saver Software, and have it ENABLED through BIOS + The Program ....then this CAN CAUSE ISSUES w/ YOUR SOUND!
Immediately upon disabling the program's features (which I had previously manually enabled myself), all my sound distortion, crackling, and poping issues disappeared! Gone! Problem solved! Once again ALL my music, videos, youtube.com videos, etc have returned to working/sounding flawless!
So, if you are out there, and facing similar issues with sound under the same circumstances/hardware I have, then check to see if that's what's causing it! I hope this helps others like myself!
Who'd of thought THAT would be the issue behind a sound problem. This almost drove me insane! Anyhow, good luck and happy computing everyone! *salute!*
Warm Regards,
Syric
MAJOR UPDATE!:
Updated BIOS (F6 to F7): Award Software International, Inc. F7, 3/31/2009
Ok, I need to follow-up this post because my popping, crackling, and other sound issues returned. The issue: Hyper-Threading (HT) turned ON! I found this out via random circumstance and a bit of luck. The short version is I had been running my system a couple days w/ Hyper-Threading turned off (recommended prior to doing a BIOS update), and then re-enabled it after I was done and got around to installing the update. Sound was fine prior to re-enabling HT.
The Issue: horrible sound quality that would cause popping, crackling, distortion, and slow-mo or speed-up effects.
The Resolve: On a i7 system running a 64-bit Vista Home Premium Edition OS, and using a SoundBlaster sound card, you may need to turn OFF Hyper-Threading in your BIOS in order to fix your sound issue(s)
Note: You may also want to forego/disable using SoundBlaster's X-FI Crystalizer. Using this seemed to cause sound improvements SOMETIMES, but more often than not it created a roller-coaster effect w/ the "percussive sounds and transients." Anotherwords, the sound would fade the music in/out constantly. This feature isn't suppose to that, but it does on my system. Another wasted feature ...for now :/
Upon me doing this, I have no further issues w/ my sound. I've tested mp3 formats, playing various CDs, and crossing between Windows Media Player and iTunes for playing this media.
CPU-Z will tell you your motherboard's make and model.
CPUID
    Intel C2Q Q6700 @ 3.2GHz
    ASUS P5N-D
    4GB G.Skill PQ
    EVGA 8800GT G92 SLi
    X-Fi XtremeMusic
    Samsung 245BW
    1920 x 1200
    WD Caviar SE16 500GB
    WD Caviar SE16 250GB
    Corsair HX-520W
    Antec P182
    OCZ Vendetta 2, Zalman VF-900 Cu, Scythe Kaze Master
    Logitech G11
    Logitech G5 Rev. 2
It looks like this is my motherboard Systemboard with NVIDIA® nForce® 720i Chipset (MCP7A-D) here are the specs for my computer
Gateway Official Site: Shop - Desktops – LX6810-01 Product Details - LX 6810 01 Product Details
I took the cover off my tower to see what sound chip I had but there are no big chips. Then I went to NVDIA to see what it said and I couldn even find my motherboard on the site. I installed the newest realtek drivers and it still gives me the cracking,poping, and slowmotion sound that gets worse over time.
Any help or ideas would be great.
I have the UD4 and cant tell you how long ive been searching someone with the same issue :p but mine is when i install the card wont start i had it running on w7 but afeter 2 reboots had the same problem, going to try your method, and thanks for sharing :)
registered to reply to your post :D
