MattNhisVista
First of all I have been on here quite a few times this is my first post. You seem such a helpful bunch I wanted to join. So, Hello. and thanks for reading.
I accidentally run "sysprep" on my machine. Vista Home Premium. It kept on booting to a completely reset profile and I could not get it to load into my normal profile. I recovered my machine to the "out of box" state using recovery.
I have a secondary hard drive and now Vista will not recognise the 2nd drive. It always used to. I can see it in BIOS and I can hear it running. During boot up it hangs at the Vista loading bar and if left long enough will go to a black / blank screen. If I take it out it will load to normal profile.
If you would be kind enough I would like to know if there is anything I can do to fix it. I have 10 years of photos on this drive and would be devastated if I lose them. This was my supposed to be my back up drive. Grrrr.
Thanks for reading and any help would be greatly rcvd. Many thanks in advance.
Regards.
Matt.
Regards.
Matt.
