Yesterday Windows Update installed Definition Update for Windows Defender - KB915597 (Definition 1.37.579.0) and asked that my computer was restarted.
After re-booting I tried to connect to the internet to play Lord of the Rings Online and I could not. I have a dial-up connection (only thing available still where i live) and I kept on getting the message:
Connecting... verifying user name and password
Error 1717: Unknown interface
I phoned my ISP and after creating a new connection and rebooting the comp with everything disabled in msconfig/startup I was able to connect. After that I re-enabled everything I needed again and internet still connected no problem but when I try to play LOTRO I get the message in the launcher: A connection attempt failed and it keeps on retrying to connect but it always fails.
I checked my Firewall and my lotro client is in the approved applications. I tried Turbine LOTRO support and asked them what to do and if I should do a system restore and they said it might not be a bad idea.
Any suggestions here? Is a system restore necessary? Or should I try to uninstall that latest security update? Anybody else have problems after that update?
