A couple of problems with Vistax64..
Xen00b
First off...I had HUGE doubts about getting Vista...and even bigger doubts about getting Vista x64.. But I have grown to love it...everything is much smoother, and I am just loving the new OS despite other's opinions.
However, I have 2 issues with it that I would like to know if anyone can give me some support on:
1st issue: My bluetooth keyboard and mouse will not stay working. They are Rocketfish brand and are Vista Compatible. They did work on my last PC that was running XP.
2nd issue: My icons will not stay put. I arranged my icons how I wanted them, but everytime I power off the PC and turn it back on they are all crammed on the left side of my screen. Any ideas on how to get them to stay where I put them?
Thank in advance,
-Xen00b
    Q6600 @ 3.4GHz
    EVGA 780i
    8GB OCZ Fatal1ty DDR2 800 (PC26400)
    EVGA GTX 280 superclocked edition
    24" Westinghouse
    1920x1200
    750GB Seagate Barracuda
    ePower 850W Zumax x4 series
    XCLIO A380PLUS Case
    Artic Cooling Freezer 7 Pro
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
    Razer Carcharias Gaming Headset & Razer Destructor Mousepad w/ eXactRest
1.) Get better drivers for your devices.
2.) Turn off auto arrange
    16GB DDR667
    SAS RAID
I just did that and it did do the trick. My drivers were apparently out of date :P.
But auto arrange isn't on on the 2nd part :S
    Q6600 @ 3.4GHz
    EVGA 780i
    24" Westinghouse
    1920x1200
    XCLIO A380PLUS Case
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
Thank in advance,
-Xen00b
Hello Xen00b,
I can't answer your 1st issue. I had 1st hand experience on your 2nd issue. What I did was first put my icons where I wanted, then I created a restore point, then did a system restore with the date I created the restore point. Hope it works for you.
I am not in front of my Vista workstation. I am at work. I will check tonight and post back.
    16GB DDR667
    SAS RAID
Thanks Brink! That fixed it ^^..they are now all staying in place.
Now my keyboard and mouse won't work again though :\
    Q6600 @ 3.4GHz
    EVGA 780i
    24" Westinghouse
    1920x1200
    XCLIO A380PLUS Case
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
Are they cordless? If the answer is yes then Brink has something ELSE you need to do to make them work lol.
    Intel Core2Quad Q9450
    nForce 790i Ultra SLI(evga)
    8 GB DDR3 1333MHz
    2 e-GeForce 9800GX2(SLI mode)
    WD1500AHFD (Raptor 150 GB 10,000 RPM)
Yes they are cordless....Bluetooth if you want to get technical >.>
    Q6600 @ 3.4GHz
    EVGA 780i
    24" Westinghouse
    1920x1200
    XCLIO A380PLUS Case
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
LOL Bubba,
Yep, get a stick and make them work. ;)
Xen00b,
Are they wireless though?
Yes, they are wireless. ;)
    Q6600 @ 3.4GHz
    EVGA 780i
    24" Westinghouse
    1920x1200
    XCLIO A380PLUS Case
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
Xen00b,
If you have a reset button on the reciever and a connect button on the mouse, then press them to sync them back together to see if that will help. Sometimes mine will do this.
I had done that before....they seem to be working fine now.
There was an issue with me having no passkey for them...but I just selected 'no passkey' and they seem to work..
I looked through the documents that came with the keyboard and mouse and it said select 'choose a passkey for me', but when I did it wouldn't work...it said that there was an error when trying to find my passkey.
I have selected 'no passkey' now though, and everything seems to be working okay....we'll see I guess ^^
    Q6600 @ 3.4GHz
    EVGA 780i
    24" Westinghouse
    1920x1200
    XCLIO A380PLUS Case
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
Shawn, did I not read on a thread that their is something that needs to be downloaded from MS to get wireless stuff to work? Or am I lost as usual lol?
    8 GB DDR3 1333MHz
I've restarted my PC about 3 or 4 times now and the keyboard and mouse have stayed sync'd through the whole ordeal. I believe my problem is solved :)
Also my icons are staying as well.
Thank you so much guys...that was rather annoying. Glad to have you here to make my day a little better lol..
    Q6600 @ 3.4GHz
    EVGA 780i
    24" Westinghouse
    1920x1200
    XCLIO A380PLUS Case
    Razer Lachesis
    Razer Lycosa Mirror
    DSL
