a problem i think with Installing exe's
Ravvie
Hey guys, for 2 days iv been really pulling my hair out with why i cant install a exe file.. I remember installing Registy Mechanic before hand and if i remember rightly a year or so ago i did the same thing but for the life of me i cannot remember why or what i did to sort it out! I have looked everywhere to work out what is wrong with my system and i really cant work out whats happend..
This particular .exe file is for the sims 3 and when i try to click the .exe file it gives me this box with this information in it..
http://i246.photobucket.com/albums/gg100/RAVAGEWOLVE/Untitled-6.jpg
Code:
Windows ® Installer. V 4.5.6002.18005
msiexec /Option <Required Parameter> [Optional Parameter]
Install Options
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
Display Options
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
Restart Options
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
Logging Options
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log <LogFile>
Equivalent of /l* <LogFile>
Update Options
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
Repair Options
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
Setting Public Properties
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
I would really appreciate it if anyone could help me!
Thanks in advance Vista Forums!!
J (Ravvi)
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
Hi J (Ravvie),
This message you see is the standard help message you get if you enter an invalid command or /? into msiexec.exe. When you try to open the setup that requires msiexec.exe to run, the wrong command is given and msiexec.exe gives you a message explaining how to use it correctly. (msiexec.exe is the main executable of Windows Installer, so any Windows Installer .exe will not work correctly)
This is because a registry entry has become corrupted (which fits with Registry Mechanic causing the problem) If you were to go and correct this registry entry, your problem would be solved. For this reason, I doubt that "sfc /scannow" would work, though it is definitely worth a try.
I do not know off hand where this registry entry is located, however I will try and locate it for you. However what I would try is to reinstall Windows Installer 4.5 over the top and see if that repairs your registry key.
Here is the download link: Download details: Windows Installer 4.5
MAKE SURE YOU DOWNLOAD THE CORRECT VERSION FOR YOUR SYSTEM!
If all else fails, you could try a System Restore or even a repair install of Vista, however I feel think this is necessary, at least not at the moment.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hey there fellas, id like to thank you all for the appreciated help! Sadly i got the hump with it and did a restore, managed to partition my HD and store what i still wanted on there any-ways! Its my first build so im learning as I go along you know :)
Also guys is there any kind of programs like registry mechanic that you can think of that would help with keeping my system tidy, i have that ashampoo auto defrag thing which i thinks pretty neat!
Thanks again for your help guys!
J
Go and download Auslogics Disk Defragment and Registry Cleaner. On the front page of Auslogics, it looks as though everything is demoware, but click on products at the top and you will see that these 2 are completely free. There is also a good free registry defragment that I will come back to you on the name of.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hiiiiiiiiii
i have also same problem but i fix it using tune up utilities.
try this :D
in tuneup utilities go to "Fix common problems" section there check
"The windows installer service cannot be accessed" follows the wizard & "restart "
the system.
  • Memory
    3GB
