OK, let me preface this by saying that I repair computers as a hobby, I do know that I'm doing usually.
Given that, I have an issue with screen brightness...
Using FN and F10 does not increase brightness (swap FN with CTRL is disabled in my bios - FN is FN)
The screen brightness indicator when I use the FN F10 key indicates the screen is at max brightness, yet at minimum there is no change in brightness.
My ambient light sensor is disabled so I COULD use the FN key to adjust brightness
I have reinstalled my chipset drivers, flashed my bios and tried damn near everything to get my brightness up.
Currently, my brightness is at minimum, despite my power options saying its full and the onscreen indicator when FN is used telling me the same.
At bootup and in the BIOS I am able to adjust the brightness and it DOES get significantly brighter (and dimmer) when I use the FN keys.
I have scoured the internet and have found nothing relating to my issue as of yet, hopefully someone here can help me out
Side note: I have a Compaq 8710w with Vista Ultimate x64 on it (yes, a legit copy)
All windows updates are done, I have even done what I normally refrain from doing - installing all of the HP / Compaq base software garbage that they like to preload in hopes of remedying my issues with the screen brightness level....
Anyone have any idea what I should do next?
-Grodii
-Grodii
- Compaq 8710w
- Core 2 Duo T7800 26 GHz
- 4 Gigs Corsair Valueselect Ram
- nVidia Quadro FX 1600m
- 1920 x 1200
- 500 Gig Seagate SATA drive
- DSL 1.5 mbit
